RichardL Senior Member
Posted: May 14 2012 at 21:42 | IP Logged
I suddenly seem to not have any triggers firing.
I see devices that should start a trigger in the event log (but only as Decode: group cleanup), but no trigger follows. All the triggers start via an "Insteon Group In". The Startup trigger (via System Process | Startup) does run.
My links, and timed events are all OK. The scripts are OK, I tested some out via "Check Formula" - all OK. I am running v2.1.4.
Any thoughts?
Thank you,
Richard
Posted: May 14 2012 at 21:50 | IP Logged
Richard,
Group cleanups are different from Insteon group In messages and will not fire your triggers.
If I had to guess, I would say that your PLM has lost its internal database so no longer can "see" the group broadcasts and can only see the group cleanup since its a direct command to its address. To fix this, use the "Add Full" button on the Setup tab of Insteon Explorer (if this is indeed the problem).
Posted: May 14 2012 at 22:40 | IP Logged
"We've got triggers!"
Yes, something was missing from the Event Log.
Any idea how this happened to the PLM?
Thank you for the help and support!
Richard
