Posted: April 22 2004 at 10:00 | IP Logged
Nick,
To increase the eventlog lines in the phstat screen, open the pwrhome.ini file and go to the [PowerHome Status] section. Set the "eventlogrows" to the value you would like to have. You'll have to restart PowerHome for this change to take effect.
To automatically open the windows stated above, first edit the pwrhome.ini file and under the [System] section, change the "openwindowonstartup" parameter to 2. This will force the X10Stat screen to be the default window. Next edit the "STARTUP" macro and add a "Send Keys" command and make it immediate. In the "Send Keys" field place the following:
"{alt+F8}{alt+a}e{alt+w}t"
This will open the PowerHome status screen followed by the PowerHome Explorer and will follow it up with "Tiling" the windows.
