nick7920 Senior Member
           | Posted: September 24 2011 at 11:36 | IP Logged
I have this vbscript to get the image from the ipcamera which runs fine. If I use the ph_run it works fine,  but using ph_runscript_0 it seems to get the image from cache and it will get new one after long time ,seems like it left the connection open. It may be working for ph_run because when you are done, it closes the command window and that will close the connection. Can someone look at the Vb code and point me to right direction.
 ph_run code
 ph_run('cmd /c "c:\sendemail\vb\getcam.vbs"')
 Option Explicit
 Dim DataBin
 Dim HTTPGET
 Set HTTPGET = CreateObject("Microsoft.XMLHTTP")
 HTTPGET.Open "GET","http://XX.XX.XX.XX/snapshot.cgi?user=test&pwd=test", False
 HTTPGET.Send
 DataBin = HTTPGET.ResponseBody
 Const adTypeBinary=1
 Const adSaveCreateOverWrite=2
 Dim SendBinary
 Set SendBinary = CreateObject("ADODB.Stream")
 SendBinary.Type = adTypeBinary
 SendBinary.Open
 SendBinary.Write DataBin
 SendBinary.SaveToFile "c:\powerhome\web\IPsnapshot.jpg", adSaveCreateOverWrite
 and code for ph_runscript_0
 ph_runscript_0(0, "c:\sendemail\getipsnap.vbs","sub1")
 @language="vbscript"
 Sub sub1()
 Dim DataBin
 Dim HTTPGET
 HTTPGET.Open "GET","http://xx.xx.xx.xx/snapshot.cgi?user=test&pwd=test", False
 HTTPGET.Send
 Dim SendBinary
 SendBinary.Open
 SendBinary.SaveToFile "C:\powerhome\web\IPsnapshot.jpg", adSaveCreateOverWrite
      ph.usermessage("Getipsnap from vb script")
 HTTPGET.abort
 End Sub
 again it seems like more of a Vbscript command to close the connection than powerhome.
 Thanks for any help
 P.S. any one who has the foscam Ip camera can use this code and will to do the job, except my little short coming till the fix. right now using from Ph_run.
