phlover Newbie
Posted: August 11 2011 at 21:33 | IP Logged
Hi Friends,
After installed PH 2.1b on win 7 x64, I get this error message:
"Error loading library.
Please check whether PowerBuilder Accessibility library can be located in the path."
Please help! Thank you very much,
Ha
Posted: August 11 2011 at 22:39 | IP Logged
Ha,
Download the Accessibility library here pbacc105.zip. Unzip it and extract the pbacc105.dll file into your system32 (or your PowerHome directory which should be c:\powerhome on Windows 7). This will resolve that error.
phlover Newbie
Posted: August 13 2011 at 16:52 | IP Logged
Hi Dave,
Thank so much! It works now, but I do have another communication-to DM error: "SmartHome Device Manager ISRESPONDING command failed for Insteon .... Attempting to restart controller..."
And I read and follow below message you posted for Chris, but it still do not work for me. I saw that my DM is talking and responding to commands, and I can turn on/off lights with DM window, manually, by commands such as 12.B1.34=ON. However, when I run PM, I get the above error message. I believe somehow PM could not talk to my insteon DM due to setup or something.
Please help and thanks,
Ha
"The first thing I would try is to shut PowerHome down as well as the SDM. Shutting PowerHome down is easy enough...to shutdown the SDM, you'll need to locate it's icon in the system tray (yellow "T" icon), click it, wait for it's window to open, click anywhere in the logging window, type the characters D M, and type haltdm in the command window.
With both shutdown, lets see if the problem is PowerHome or the SDM. Manually launch the SDM by navigating to the PowerHome SDM directory (default c:\program files\powerhome\smarthome\device manager) and launching SDM.exe. The yellow "T" should appear in the tray. Click it to activate it, type the D M to open the command window, and type isresponding followed by enter. If that returns true, next try typing getplcstatus and confirm its results. If all looks well including the PLC address, try launching PowerHome."
phlover Newbie
Posted: August 13 2011 at 17:34 | IP Logged
I got it works now. All I have to do is turn UAC off.
Thank you very much for your help,
Ha
