PowerHome Bug Reports
Subject Topic: ph_macro does not execute immediately Post ReplyPost New Topic
patc
Posted: March 08 2004 at 16:07 | IP Logged Quote patc
When I execute macro via a ph_macro in a formula before it executes the next line of the macro I'm in it seems to execute first then the macro called by ph_macro. Normally, I would use the Macro option where "Immediate" or "Post" can be set but I want to have a selected macro execute as in:
ph_macro(case(condition when 1 then "MACRO1" when 2 then "MACRO2".... <SCRIPT language=javascript>postamble();
Can I control this some way?
Back to Top View patc's Profile Search for other posts by patc
patc
Posted: March 08 2004 at 16:09 | IP Logged Quote patc
patc
Posted: March 08 2004 at 16:12 | IP Logged Quote patc
I seem to be spiralling out of the PH community. The strange <SCRIPT lang.... used to come up after my signature but now it pops up in the middle of my posts.
I will get a dead chicken and some bats wings and try to exorcise this. <SCRIPT language=javascript>postamble();
Posted: March 08 2004 at 17:19 | IP Logged Quote dhoward
Pat,
If the ph_macro is being called in a formula that is "Immediate" rather than "Post", then it should execute before the next macro line executes.  I ran a couple of tests and verified using the PowerHome Status eventlog and all appears as it should be.
Now if the ph_macro appears in a formula that is "Post", then the formula is posted to the execution queue and is executed the first chance it gets.  This would be after the current macro terminates, launches an input or message box, or Waits.  A "Delay" command will not allow the execution queue to be processed.
Are you wanting the macro to execute immediately or after the current macro is executed?  If you want the macro to execute immediately, then your statement above should be fine, just make sure that the Formula is "Immediate".
If you want the macro to execute after the currently executing macro, its a little trickier.  You'll still want the formula to be "Immediate" but instead of just a ph_macro, you'll want to use a ph_postformula with the ph_macro inside like this:
ph_postformula('ph_macro("' + case(condition when 1 then "MACRO1" when 2 then "MACRO2") + '")')
What will happen above is that the "case" statement will be evaluated when the current macro is executed.  This is probably what you want since the "conditions" probably won't apply if the whole formula was posted.  The resulting string 'ph_macro("WHATEVER THE CASE STATEMENT RETURNED")' will then be posted to the execution queue.
Probably more that you wanted to know and not sure if I answered your question .
Posted: March 08 2004 at 17:21 | IP Logged Quote dhoward
If you figure out whats causing the <SCRIPT language=javasc..., let me know .  Im curious myself whats been causing it.
Ive been thinking I should add it to all my posts just so you won't feel so special.
patc
Posted: March 09 2004 at 08:38 | IP Logged Quote patc
patc
Posted: March 09 2004 at 09:16 | IP Logged Quote patc
your running a test on ph_macro led me to trying to duplicate your results. My test also showed via the Event Log that indeed the statements in the calling and called macros are running in the correct order but I'm not sure how to interpret my test results.
Here's what I did. In the calling macro I put a user msg after the ph_macro and a user message further down before a msg box. In the called macro I put a user msg as first stmnt and a user msg further down before a msg ox.
The user messages show up in the correct order on the Event Log. The message boxes however are not popping up the way I expect. First the msg box from the called macro pops up, then the msg box from the calling macro pops up before the first box is cleared or the called macro finishes. I am making assumptions based on the order that msg boxes are stacked on the screen.
A few more tests indicate that before the called macro completes, execution flow in the calling macro proceeds until it hits a msg box.
Pat
patc
Posted: March 09 2004 at 09:22 | IP Logged Quote patc
The last post was also in the nature of a test of the
line that pops up in my posts. Since I'm sending these posts from a different computer without getting the line the problem seems isolated to something going in my main computer.
I don't know what the something is yet but it narrows the problem area down.
Pat
Posted: March 09 2004 at 14:09 | IP Logged Quote dhoward
Pat,
Your observations are correct.  Whenever a Message Box or Input Box command is processed, the macro info is stored within the message/input box and the macro is terminated.  This allows other macros or items in the execution queue to be processed.  When the message/input box is closed, the macro is reloaded into the execution queue and resumes where it left off.
Essentially, message and input boxes do not hang execution queue processing.  For all practical purposes, a macro is finished when it opens an input/message box.  When the box is closed (or times out), the macro is restarted where it left off.
patc
Posted: March 09 2004 at 16:47 | IP Logged Quote patc
I can see the sense of not holding up the execution queue when a message or input box is waiting for input.
From what you said it seems that the ph_macro launches the called macro and then proceeds to the next statement of the macro that the ph_macro resides in. Is this correct? If it is how do I get the calling macro (the one with the ph_macro in the formula) to launch the called macro and then wait until the called macro completes?
I suppose a "wait" or "delay" would hold it up but I'd waste a lot of user time that way.
Posted: March 09 2004 at 17:07 | IP Logged Quote dhoward
Pat,
As long as the ph_macro is called in an "Immediate" formula and you don't have any message/input boxes or wait commands, then the calling macro WILL wait for the called macro to complete before continuing execution.  You should be able to verify this using just user messages in your macros.
Definately don't try to use delay or wait because you shouldn't have to.
If you have a particular sample that this doesnt seem to work for, please send it to me or post it here so I can test it.
patc
Posted: March 09 2004 at 17:48 | IP Logged Quote patc
I guess I'm having problems because I do have message/input boxes in both the calling and called macros. I generally design my programs with a mainline macro and lots of called macros. This usually gives me a lot of flexibility for reusable macros and ease of testing via small chunks of code.
I'd really like to stay with this format.
Would it make any sense to let the macros do some some handshaking like:
mainmacro: glbl=0; lbl="top"; call submacro; wait 1; goto(if(glbl=0,"top","next"); ...rest of mainmacro ...
submacro: do this; do that; glbl=1; done;
or does this get me into more trouble with the way PH wants work?
PatC
patc
Posted: March 09 2004 at 17:50 | IP Logged Quote patc
Oops! I meant
mainmacro: glbl=0; call submacro; lbl="top"; wait 1; goto(if(glbl=0,"top","next"); ...rest of mainmacro ...
PatC
Posted: March 09 2004 at 20:50 | IP Logged Quote dhoward
Pat,
You raise a very interesting question and you've got a valid point...How do you make the main macro wait until the submacro is truly finished?
Ive turned it over and over in my head and can't really think of a better way than you describe.  Basically use a global var as a flag for whether the submacro is finished and have the main macro loop using a Wait command (be sure and use a wait and not a delay...the delay command does not allow control to be returned to the execution queue) until the global var is changed.
I wish there was a better way but I think you've already come up with it.
PowerHome used to work they way you expected...a message/input box halted all execution until the box was closed.  I changed it several versions back as this was causing problems because a macro would run and I would be at work and my whole system would be hung until I got home.
If you're interested, I could look at adding a couple of new macro commands with message/input boxes that will wait until closed.  That way you could have a choice between the current boxes or ones that hang the system until closed.
Nothing wrong with your programming style , I do the same thing...It's definately the way to go.
Let me know if you're interested in having new message/input boxes or if you're just as happy using the "flag and wait" method.
patc
Posted: March 10 2004 at 18:44 | IP Logged Quote patc
the "flag and wait" works fine for what I'm doing. It does add a few more lines to my macros everytime I call a macro. For a mainline macro it can get a little cluttered but its workable.
I'm not sure if the optional message/input boxes would work. I think that a macro command with a wait/nowait or ph_macro(s,n) that allows waiting until the called macro finishes would do it.
PatC
Posted: March 10 2004 at 23:46 | IP Logged Quote dhoward
Pat,
Ive been thinking about the problem and have come to the conclusion that the optional message/input boxes that don't give control back to the execution queue is probably not the way to go and have been thinking about implementing exactly what you propose.
Ive been going over it in depth, and I think what Im going to do is create a new Macro command that allows you to launch what Im going to call a SubMacro.
Its rather complicated to explain the inner workings of PowerHome, but I believe I can do this without too much trouble.  It will mean that a SubMacro however won't get its own set of internal variables but will instead inherit the calling macro's variables.  I'll have to create a couple of extra internal variable structures to track the calling macro/line to submacro/line to submacro/line, etc. to keep track of the levels as they are  traversed.
patc
Posted: March 11 2004 at 15:04 | IP Logged Quote patc
consider this a vote for macros that "wait". Although I said that I could implement the same effect via the "flag and wait" scheme it has a couple of glitches that I hope you will eliminate.
First, the cycling wait loop gives PH an eerie pulse effect. Almost like it has a heatbeat. It is one way to know its alive though.
Second, for input boxes in the called module, I found that I had to tweak the wait time or I couldn't get any characters typed unless I got the rhythm just right because of control switching back and forth. Gamers would probably love it though.
Re, the submacros not having their own variables: this could be problem for macros used recursively. If you're not going to allow recursion then its moot.
PatC
Posted: March 12 2004 at 16:20 | IP Logged Quote dhoward
Pat,
Ok, Ive gone through and Ive added the functionality.  It works great!!
When I say the submacros won't have their own variables, I mean they won't have their own unique copy.  A submacro will inherit the calling macro's variables.  This refers mainly to the local and temp variables.  I had to do it this way because there would be no way for me store the calling macro's variables in situations where you have a macro calling a submacro calling a submacro calling a submacro, etc. since the memory structure is so complicated.
I know what you mean about the pulse effect.  Thats exactly what I got when verifying the functionality.
patc
Posted: March 14 2004 at 22:38 | IP Logged Quote patc
I see that you've been busy while I was away for a few days. Let me be the first to thank you for adding this feature. Will there be an entirely new macro with a wait or will the existing macros have an option to wait?
Also, you said you experienced the pulse effect. I'm curious to know if you had any difficulty typing into input boxes in the called macro. I did because of the way I implemented the functionality.
Pat <SCRIPT language=javascript>postamble();
PatC
Posted: March 22 2004 at 17:23 | IP Logged Quote dhoward
Pat,
Sorry to take so long to respond...missed your message.
Not a new macro, just a new macro command called "Submacro" instead of macro.  It doesnt have an immediate or post (it's always immediate) and instead of a dropdown ID list like the macro command, you can have a formula that evaluates to a macro ID in the Sendkeys field.
As I recall, I didn't have too much trouble typing in the input boxes.  Occasionally a key was missed if it was typed right when the pulse effect was happening.
I'll be putting out a beta soon with this latest functionality as well as some more implemented.
Page of 3 Next >>
