sifu128 Groupie
Online Status: Offline Posts: 62
Posted: February 08 2011 at 18:58 | IP Logged
Hey guys, I have a fast controlcenter question. I ran the wizard two times and now I have multiple entries. Is there anyway I can remove the ones that I do not want or need? I do not see anyway on how I can do this via the Powerhome Explorer.
TIA
Dave
sifu128 Groupie
Posted: February 09 2011 at 10:11 | IP Logged
Anyone? :)
Posted: February 09 2011 at 10:36 | IP Logged
In PowerHome Explorer, navigate to PowerHome|Control Center (on the left). In the right hand pane, you will see a list of CC tabs that were created. Right click on a line item and from the dropdown menu, select delete to remove that particular tab. Press "F5" (or navigate to a different Explorer screen, close the explorer, etc.) to save the changes. Close the CC screen if open and reopen it and you'll only have the CC tabs you didnt delete.
Of course, you can also delete ALL the tabs and re-run the wizard. What surprises me is that the wizard should have overwritten your previous CC screens unless you changed the locations or similar which would have resulted in different CC ID's. IOW, if you want to preserve a wizard generated CC screen, rename the ID in the PowerHome Explorer so it won't get overwritten the next time the wizard runs.
sifu128 Groupie
Posted: February 09 2011 at 10:50 | IP Logged
Works perfect!!! THANKS!
Do you think that this is a bug that I was able to run the wizard two times and it added both?
