benjaminkeith Newbie
Posted: January 15 2011 at 23:37 | IP Logged
I am looking to create a network of motion sensors in my house that would trigger lights when I walk into a certain area. Also I would like the level of light to be determined by the time of day.
I.E. if I walk into the hall at 5pm the lights would be turn on to 100% but if I walk down the same hall at 2am the lights would turn on to 30%. Is this possible with power home?
Also, I know that I would need to have all the switches controllable, I was thinking insteon switches for this. But what kind of motion sensors would you recommend? I would like to have something that would be wired in so that I would not have to change batteries and I guest it would be more reliable. Any thoughts would be very helpful
Thanks.
Edited by benjaminkeith - January 15 2011 at 23:38
Posted: January 16 2011 at 01:22 | IP Logged
If you are thinking Insteon there is only one Motion Sensor to choose from – 2420M. it is a battery device but a 9V battery eliminator can be used. Whatever lights you are want to control would require an Insteon switch(s) to control them.
As for time of day differences, this can be done with Powerhome. PH offers various ways to program a solution. One way would be to define a Trigger which fires when the Motion Sensor sends an On command (motion detected). The Trigger invokes a Macro which turns on the respective light at different Bright levels based on time of day.
Since it sounds like you do not have Insteon at present there are some other devices that are necessary to support Insteon usage and Powerhome. A PLM (2412 or 2413) for PH to powerline communication, a pair of Dual Band (powerline and RF communication) devices to couple the 2 120V legs. These are in addition to the Motion Sensors and Insteon switches (several choices here) for controlling the various lighting circuits.
Posted: January 16 2011 at 08:28 | IP Logged
Thank you for your detailed response. You said “If you are thinking Insteon” would there be a better way to go about this?
Posted: January 16 2011 at 11:04 | IP Logged
No alternate suggestion. I use Insteon. Just wanted to be sure I was responding to the right question. X10 is another alternative which I have used and did not find it reliable enough to consider using on this scale. PH supports UPB but I know nothing about UPB devices.
Edited by grif091 - January 16 2011 at 11:06
Posted: January 16 2011 at 21:22 | IP Logged
Thanks for all your help.
