syonker Senior Member
| Posted: September 24 2010 at 10:48 | IP Logged
Hi Gang,
Two things that elude me are 1) Program Logic and 2) Debugging tips/hints. So that said, let me ask the following questions in an effort to "Learn to Fish"...:
1) Is there a "step" function when running a macro that allows you to see I/O, and errors?
2) Is there a log or something with error codes, and a place to look them up?
3) Has anyone written a Programmer's Guide that would show examples of logic and flow control, etc?
...and of course, I have a specific problem to deal with...this Macro is throwing a Syntax Error...can anyone see the obvious problem, because I sure don't - I've compared it to other macros in my line-up, and to examples on the board...
><(((º>`·.¸¸.·´¯`·.¸><(((º>¸.
| Posted: September 24 2010 at 11:11 | IP Logged
I should state that the Goto Label function with both results going to "FANON" is on purpose...either way, it runs through "FANOFF" - even in this case.
| Posted: September 24 2010 at 11:20 | IP Logged
Unless there is some function in the Macro that is not working the way you want it to ignore the syntax error message in the event log. There is a known problem with the Insteon command for commands that do not have a cmd2 value (such as Fast On and Fast Off). PH2 is trying to validate cmd2 when no value can be specified.
No single step function that I know of.
| Posted: September 24 2010 at 11:35 | IP Logged
grif091 - THANK YOU SO MUCH! I was pulling my hair out on this one - the Macro WORKS....I changed it to use Jump Commands because I simply couldn't see the error and whether it was in the logic of the labels, gotos, formulas, etc. Here's what I have now and it seems to work fine:
| Posted: September 24 2010 at 11:56 | IP Logged
FYI, labels themselves don't get quotes.
| Posted: September 24 2010 at 12:03 | IP Logged
Tony found the problem with the Label/Goto Label. No quotes on the Label statement, quotes on the Goto Label string.
Label/Goto Label tends to be a better approach in most Macros because they are not affected by changes to the Macro over time the way Jump line numbers are.
Sorry I missed the quotes on the Label statements.
| Posted: September 24 2010 at 12:04 | IP Logged
TonyNo and Grif - Thanks again - I didn't find anything about whether quotes around labels were required...I'd seen macros both ways...this is very valuable information.
| Posted: September 24 2010 at 12:49 | IP Logged
Ok, one last posting - based on the information you two provided (for which I am EXTREMELY THANKFUL), I re-built the macro like this, with some messaging so I can see the status changing along the way:
| Posted: September 24 2010 at 13:18 | IP Logged
Dave offered a suggestion regarding Labels that I have found useful. Because a Goto Label for a label that does not exist does NOT result in a syntax error you can code if(x=y, “TrueLabel”, “Next”) where “Next” has not been defined. The effect is a True condition goes to the TrueLabel, a False condition falls through to the next sequential Macro statement. Avoids having to define a Label to execute the next sequential statement on the False condition.
GoTo Label If (x=y,”TrueLabel”, “Next”)
next sequential Macro line executed when the If condition is False
Label True Label
The Skip column is also useful. Once the Macro has been defined and debugged the User Message statements can be eliminated by checking the Skip column for those statements. The messages can be restored if further debug is necessary in the future simply by removing the check in Skip.
