        | Lenny Senior Member
           | Posted: May 23 2010 at 11:40 | IP Logged |   |
 |  Maybe I'm not going around this the best way. I want to process code IF and only IF 2 GlobalVariables are TRUE.
 So IF MODE=VACATION and OHDSTATUS=OPEN perform action.
 I'm putting this in a single entry in my macro that updates keypad buttons for OHD Status since it's executed every time the state changes.
 It seems to be ignoring the 1st IF anf processing it as true. Works fine with 1 IF.
 /*VACATION MODE OVERHEAD DOOR ALARM*/
 if("{MODE}" = "VACATION",if("{OHDSTATUS}" = "OPEN",ph_sendsmtpemail ("My.smtp-server.com", 25, "FROMeMail", "TOeMail", "OVERHEAD DOOR OPEN!", "VACATION MODE ACTIVE - OVERHEAD DOOR OPEN!"),0),0)
        | sjvonstein Groupie
          Your ordering of the if statements appears to be correct.  Are you receiving any formula syntax errors?
           | Posted: May 23 2010 at 12:20 | IP Logged |   |
        | sjvonstein Groupie
          *Deleted*  See better suggestion below.
           | Posted: May 23 2010 at 12:32 | IP Logged |   |
 Edited by sjvonstein - May 23 2010 at 15:44
        | jbbtex Senior Member
          So you want one action if both statements are true and
           | Posted: May 23 2010 at 14:54 | IP Logged |   |
 |  another action if either are false?  Then try this way.
 if("{MODE}" = "VACATION" AND "{OHDSTATUS}" =
 edit: removed extra ',0)'
 Edited by jbbtex - May 23 2010 at 21:12
 Brady
        | Lenny Senior Member
           | Posted: May 23 2010 at 19:16 | IP Logged |   |
| jbbtex wrote:
       | So you want one action if both statements are true and another action if either are false?  Then try this way.
 Doh, now I feel dumb :) I was thinking If/If or If/Then... Changing to single IF with AND operator and removing the last ,0  it works as it should.
 Thanks so much
 Edited by Lenny - May 23 2010 at 19:18
