doctorjerry Groupie
Online Status: Offline Posts: 57
Posted: December 20 2009 at 23:20 | IP Logged
Is powerhome compatible with Windows 7?
__________________ Jerome
Posted: December 20 2009 at 23:23 | IP Logged
Yes I’m running it on 7.
nadler Super User
Posted: December 21 2009 at 07:53 | IP Logged
I just upgraded from XP Pro to Windows 7 Pro (64 bit) last
week and am running PH. PH 2.1b runs right out of the box.
The only issues I had were that W7 changed all my comm port
numbers so I had to go into my macros and change them
there. Also one of my USB to serial converters doesn't
work while a second one works, so I need to buy a new one.
Lastly I needed a new USB UIRT driver (which I downloaded
from their site).
Posted: December 21 2009 at 08:43 | IP Logged
PH runs fine but the sensitive issue is the drivers that Noel pointed out. Even though they may pass the Compatibility test they still might not work. I have also found some software is not upward compatible and I thought that was one of the advantages over Vista. Benchmarking the speed I found Win7 equal to XP and much faster than Vista.
kev21986 Senior Member
Posted: December 21 2009 at 12:06 | IP Logged
I ran PH on Windows 7 for a few days without issues. I
ended up downgrading back to XP because of problems
with other unrelated programs.
@respectTheCode
