jeffw_00 Super User
Posted: November 14 2009 at 13:25 | IP Logged
I would like to find a way to export the database so that it can be parsed by, say, a perl script. I want to use this to compare 2 databases and look for differences.
I had been exporting the database using this script...
insert into macroheader values ('DBEXPORT','DB Export',0,0,1);
insert into macrodetail values ('DBEXPORT',1,15,'[LOCAL2]',NULL,'"c:\jeff\insteon\db\exporteddb_" + string(today(),"yyyy-mm-dd")',0,'');
insert into macrodetail values ('DBEXPORT',2,15,'[LOCAL3]',NULL,'1',0,'');
insert into macrodetail values ('DBEXPORT',3,26,'',NULL,'LOOP',0,'');
insert into macrodetail values ('DBEXPORT',4,15,'[LOCAL1] ',NULL,'ph_regexdiff1(",",",",",macroheader,macrodetail,inst eondevices,timedevents,triggers,exit,",1, [LOCAL3],0,0,0)',0,'');
insert into macrodetail values ('DBEXPORT',5,16,'',NULL,'if("[LOCAL1]" = "exit",999,1)',0,'');
insert into macrodetail values ('DBEXPORT',6,38,'',0,'ph_sqlselect(1,"select * from [LOCAL1] order by 1,2") + ph_writefile("[LOCAL2].htm",0,ph_gethtmldata(1)) + ph_sqldestroy(1) + ph_addtovar(1,3,1)',0,'');
insert into macrodetail values ('DBEXPORT',7,27,'',NULL,'"LOOP"',0,'');
Which, to be honest, I'm not sure I understand. I think I got it from a thread that suggested that this data could be used to re-construct a corrupted database, so now when I do a backup I run this script in addition to generating a backup file, but now I'm wondering if the output file is useful for anything except viewing (which might have been the original purpose, not sure).
Anyway, if I try to convert this HTML to text, I get tables with multi-word headers and blank table entries, so it's impossible to parse a row because the number of tokens varies so widely.
I guess I'm wondering if there's a way to write the database out in something like CSV format, and also whether there's a way to export the entire database that will allow easy import (i.e., an ASCII backup).
Edited by jeffw_00 - November 14 2009 at 13:29
jeffw_00 Super User
Posted: December 05 2009 at 14:51 | IP Logged
bump?
jeffw_00 Super User
Posted: December 20 2009 at 17:27 | IP Logged
aw, come on guys - it's a legitimate question 8-}
kev21986 Senior Member
Posted: December 21 2009 at 12:17 | IP Logged
This is an interesting question. There should be a way to
dump the database to sql. You could then parse the sql find
and fix the problem in the sql script. Then clear the
database and run the script. This is all theory though. No
idea how to go about doing it in PH.
I would be interested in a way to backup and restore the
database. There is a lot of time put into setup and it would
be really sad if it was all lost.
@respectTheCode
Posted: December 21 2009 at 13:10 | IP Logged
Backing up the PH database is as easy as making a copy of pwrhome.db All the macros, triggers, device definitions, link information are contained in that one file.
Posted: December 21 2009 at 13:46 | IP Logged
You also need to backup the INI file.
jeffw_00 Super User
Posted: December 21 2009 at 13:50 | IP Logged
Yup - I wrote a perl script that copies and renames both these files with a date extension. Then I wrote a macro to call the perl script. Then I created a control center button to call the macro. Push the button, get a backup.
However, when I code in my day job, I always like, when I'm done, to compare what I did with what I started with. There's no easy way to do this within PH. If there was a reasonable way to write out the database, a little perl could do a compare and DIFF the parts that changed...
Posted: December 21 2009 at 13:56 | IP Logged
I do a
PH_BACKUPDB ( "C:\POWERHOME\BACKUP\PH_CHC.DB", 1)
Then
ph_copyfile("C:\POWERHOME\BACKUP\PH_CHC.DB", "C:\POWERHOME\BACKUP\PH-CHC" + " " + string (month (today())) + "-" + string (day (today()))+ " " + string (hour(today())) + string (minute(today())) + ".DB", 9)
This is in a macro that fire every night.
Posted: December 21 2009 at 21:58 | IP Logged
I agree that an export option would be nice, but it would be HUGE! lol
jeffw_00 Super User
Posted: December 21 2009 at 22:10 | IP Logged
huge = big file? or
huge = big effort?
I actually doubt the latter. I'd be willing to bet there's an SQL command that would do a nice job.
jeffw_00 Super User
Posted: December 21 2009 at 22:11 | IP Logged
hey beachbum- why do it every night? I do it only after I make a change - am I missing something?
Posted: December 21 2009 at 23:09 | IP Logged
I make changes all the time as I am playing so I never know…
Posted: December 22 2009 at 08:12 | IP Logged
jeffw_00 wrote:
huge = big file? or
huge = big effort? |
Big file.
jeffw_00 Super User
Posted: December 22 2009 at 09:49 | IP Logged
my PC has a TB drive, I think I can handle it 8-}
Posted: December 22 2009 at 22:36 | IP Logged
Ya got me there.
RichardL Senior Member
Posted: December 29 2009 at 12:09 | IP Logged
Is there a problem if a backup is executed while the application is running and the database is open?
I shutdown PH, do the backup and restart PH...
Thanks.
Posted: December 29 2009 at 13:09 | IP Logged
I do mine in the middle of the night from a macro. So the answer would be no.
hotcoffee76 Newbie
Posted: December 30 2009 at 14:13 | IP Logged
There are lots of tools out there that can compare databases. I'm sure there is something for < $100. The cost may be worth it depending on how much time it will take to write the parsing and compare routines.
