anthonyb Newbie
Posted: October 06 2009 at 08:43 | IP Logged
Does anyone know if the RedRat3-II (the currently available version) is compatible with PowerHome as it uses a different device driver and SDK ?
Thank You
__________________ anthonyb
Posted: October 06 2009 at 15:51 | IP Logged
Anthony,
I took a look at the RedRat website and from what I read, I believe it should work. However, I don't have an actual RR3II device so I cant say for sure.
Im assuming you're new to PowerHome and so probably are doing research. If you already have this device, PH has a 30 day trial and you could see if it works or not. If it doesnt, then I could work with you to try and get the support added.
anthonyb Newbie
Posted: October 08 2009 at 09:13 | IP Logged
Thank you for your rapid reply and the offer of support. I have commited myself to PowerHome for my automation and am still on the first bit of the learning curve, I have not bought a RR3-II yet, but thought I might get one for future control coverage.
PowerHome seems to be unlimited in the ways that it can be configured and more than lives up to it's name.
It will be a while before I am fully functional with it but it will be worth the effort.
