mike0999 Groupie
Online Status: Offline Posts: 56
Posted: July 09 2009 at 01:20 | IP Logged
I am getting the following error pretty frequently, sometimes Powerhome actually crashes and gives me this error. Any thoughts? (Actually, the second line I have set forth below may not be the exact language of the error, but it is something like that. I'll put the exact language, if needed, when it happens again).
Unable to load library.
Unable to find Powerbuilder Accessibilty library in the path.
mike0999 Groupie
Posted: July 09 2009 at 03:06 | IP Logged
The second line of the error is actually the following:
Please check whether Powerbuilder Accessibility Library can be located in the path.
Posted: July 09 2009 at 09:22 | IP Logged
I too periodically see this error message when starting PowerHome. I think I had a post about it.
It only happens when I connect to my PH machine via RDP (but it only happens about 1 out of 4 times). I just hit enter, and the error goes away (it doesn't cause PH to crash or lock), so it it not a big deal to me.
