Posted: May 25 2009 at 11:41 | IP Logged
This formula will return the current valve status as a value from 0 to 8. A value of 0 means off with 1 thru 8 (0 - 7) representing the current valve that is on.
ph_setvar_a(1,1,ph_insteonwithret("EZRAIN ID",68,2)) + if(ph_and(ph_getvar_n(1,1),128) = 128,ph_and(ph_getvar_n(1,1),7) + 1,0) |
Be sure and replace the "EZRAN ID" with the ID of your EZRAIN device.
Edited by dhoward - May 25 2009 at 11:42
