williammanda Groupie
Posted: January 03 2009 at 18:39 | IP Logged
I'm having trouble getting the web center working. When I select web center it displays the webpage cannot be found. I went into powerhome/setup/web and enabled web server, set user id and password, and entered all the ip addresses into trusted ip's. I have re-init and rebooted the computer. Any ideas?
Posted: January 12 2009 at 12:10 | IP Logged
The following are screenshots:
I just entered the user ID and password they weren't based on anything that I could see that was used by Powerhome. Also the pc ip address is 192.168.1.103.
This the result I get when I call up the webcenter
I have tried these two url's also:
http://127.0.0.1/ph-cgi/main
http://192.168.1.103/ph-cgi/main
Edited by williammanda - January 12 2009 at 12:17
Posted: January 12 2009 at 13:40 | IP Logged
Firewall?
Posted: January 12 2009 at 15:33 | IP Logged
No windows firewall but the router has one. This was working on ver A with no changes to the router.
Edited by williammanda - January 12 2009 at 15:46
Posted: January 12 2009 at 19:26 | IP Logged
Quote:
This was working on ver A with no changes to the router. |
Oh, man. No issues here.
nadler Super User
Posted: January 12 2009 at 19:37 | IP Logged
After you setup the web server as above you have to
reinitialize PH. Then try http://127.0.0.1/ from a
browser on the SAME PC that PH is running on.
That should work.
After it works from the PH PC you can try the other
addresses from other PC on your local network. If you
try to access PH from the web it is likely that you will
have to change your firewall in your router.
Posted: January 12 2009 at 19:38 | IP Logged
Help me out buddy!
Posted: January 12 2009 at 19:51 | IP Logged
Got the same problem 127.0.0.1 doesn’t work either.
bhlonewolf Senior Member
Posted: January 12 2009 at 20:02 | IP Logged
Try adding "*" (without the quotes) as a trusted IP address... see if that helps...
Posted: January 12 2009 at 20:06 | IP Logged
Nadler
Typing http://127.0.0.1/ into the browser worked then I selected Web Center and it worked.
