        | cmhardwick Senior Member
          Maybe this is coming from programming background, but is there a way to have an IF statement execute multiple commands/steps?
           | Posted: July 12 2008 at 17:39 | IP Logged |   |
 For Example:
 If (a=1,{
 command 1
 command 2
 command 3},{
 command 1 if false
 command 2 if false}
 I know in PH, the curly brace I used above is for Global Variables. What I'm wanting to do is update the other controllers and keypad buttons when a device is changed programatically, without having to use up a bunch of groups. I can issue the groupcu command to update the button state or the insteon command to update a controlling switchlinc status, but not both.
 Cicero, Enjoying automation!
        | jbbtex Senior Member
          I haven't tried it but I bet you can string formula together with +.
           | Posted: July 12 2008 at 18:09 | IP Logged |   |
| Code:
       | if(a=1,ph_insteongroupcu("Kitchen","Sink",19) + ph_insteongroupcu("Kitchen","Table",19), ph_insteongroupcu("Kitchen","Sink",17) + ph_insteongroupcu("Kitchen","Table",17)) |  |  |
 Let me know the results.
 Brady
        | TonyNo Moderator Group
          Yup. Just use a '+'...
           | Posted: July 12 2008 at 20:02 | IP Logged |   |
| Code:
       | if ( {condition}, {thing1} + {thing2}, {thingA} + {thingB} ) |  |  |  |
          Great! Thanks. I knew it had to be easy
           | Posted: July 12 2008 at 21:10 | IP Logged |   |
