ginigma Senior Member
Posted: March 26 2008 at 18:42 | IP Logged
Tigra Slider Web Control
Using the controls from http://www.softcomplex.com/products/tigra_slider_control/, I was able to create the slider controls I was looking for my Insteon based lighting. Dave modified the slider.js file (renamed slider_ph.js) that comes with that package to embed the /ph-cgi/devicebtn command (which is set for Insteon. If you want to use something different, e.g. X10, search that file for the devicebtn command and make the appropriate changes.) Overwrite the original slider.js file with the slider_ph.js file.
2008-03-26_184115_slider_ph.zip
Other changes to the original Tigra code include:
- There is an additional variable value in the "A_INIT" section called "s_lightid". This is where you type your Insteon Device ID for a particular slider.
- Inclusion of an inline frame to redirect the output of the Insteon lighting commands. Without this, it won't work (slider.js has been modified to work with this). The inline frame allows you to change your lighting without refreshing the entire page.
I've put the control in a table cell. The whole table is within a form, with the following settings:
<form action="Lighting-FamRoom.psp" method="get" name="Lighting-FamRoomSlider">
The code in the cell looks like this:
<input name="sliderValue" id="slider1" type="hidden" size="3">
<script language="JavaScript">
var A_TPL = {
'b_vertical' : false,
'b_watch' : false,
'n_minValue' : 0,
'n_maxValue' : 100,
'n_step' : 2,
'n_controlWidth': 280,
'n_controlHeight': 30,
'n_sliderWidth' : 40,
'n_sliderHeight': 40,
'n_pathLeft' : 0,
'n_pathTop' : -5,
'n_pathLength' : 240,
's_imgControl' : 'images/imgSliderControl4.png',
's_imgSlider' : 'images/imgSliderButton.png',
'n_zIndex' : 1
var A_INIT1 = {
's_form' : 0,
's_name' : 'slider1',
's_lightid' : 'FAMILY ROOM 01',
'n_value' : <% int(ph_getinsteonlevel("FAMILY ROOM 01"))*100/255 %>
new slider(A_INIT1, A_TPL);
</script>
Obviously some info in there needs to be customized to your situation, but the name:value pairs are well documented in the Tigra documentation.
Additional slider controls can be put on the page just by adding additional "A_INIT" sections. This is discussed in the Tigra documentation.
The inline frame has the following settings:
<iframe src="/ph-cgi/blank?type=0" id="output" name="output" style="display:none"></iframe>
Thanks to Dave (and TonyNo for other PSP answers) for getting this to work.
