rebelzrule Newbie
Posted: January 22 2008 at 20:42 | IP Logged
I have over 50 Insteon devices in my home, and I am looking for a link management software. I'm sure these questions have been answered many times, so if it is easier, just point me in the right direction and I will look for the answers.
Is there a free trial?
Will Powerhome automatically discover all of my installed Insteon devices, or will I need to manually add them?
Will it discover my existing links?
Will my links remain intact evenif my computer if off?
gatchel Newbie
Posted: January 22 2008 at 21:19 | IP Logged
30 Days
Sort of, You can spider to find links or hit the set buttons on each device.
Once each device is found it will find all of the links.
I only use powerhone to add, change, modify Insteon links. It works well.
Support here is excellent!
__________________ Sign Here:____________________
cmhardwick Senior Member
Posted: January 22 2008 at 21:32 | IP Logged
The links are still stored in each devices, as required by Insteon. It creates it's own database copy of all these links. One of the greatest advantages of this is when you have a device lockup and have to do a factory reset (which clears it completely) or you replace a device. PH will handle recreating all the links automatically for you. It's a great time saver!
jeffw_00 Super User
Posted: January 23 2008 at 10:18 | IP Logged
A bit off-topic, but maybe this helps (and keeps me from re-typing).
http://www.techmall.com/topic.asp?TOPIC_ID=2323
