kemaa Newbie
| Posted: November 10 2007 at 17:39 | IP Logged
I've finally worked out my set of macros that speak out the forecast but I've got a little beef to pick. At the conclusion of whatever is being said is tacked on a 'zero'. It sounds a little wierd when "20 percent chance of showers... zero" Is there a way to eliminate that?
| Posted: November 10 2007 at 20:02 | IP Logged
Sounds like a formula is incorrect (this is not normal).
Maybe you can post what you are using.
kemaa Newbie
| Posted: November 11 2007 at 18:03 | IP Logged
ph_tts("{CURFORECAST}")
CURFORECAST has the text for the forecast which is read out.
| Posted: November 11 2007 at 18:23 | IP Logged
Mmmm k. Must be what you are using to populate that Global.
kemaa Newbie
| Posted: November 12 2007 at 18:52 | IP Logged
Command: TTS Sendkeys/TTS/Dim/Formula: ph_tts("Testing") yields "Testing... 0"
| Posted: November 12 2007 at 19:07 | IP Logged
Sounds like a bug to me.. No pun intended. I got the same result. It is like the return code is echoing back. Maybe Dave will chime in...
| Posted: November 12 2007 at 19:41 | IP Logged
Oh! That line should be type Formula, not TTS.
