        | eHomeCreations Groupie
          All.
           | Posted: April 06 2007 at 15:19 | IP Logged |   |
 From eHome I am trying to activate the instance of Powerhome that is currently running and bring it to the foreground. Normally I would call the API and search for the caption of the program and get the hwnd and then send a API message to activate it.
 I am not able to find powerhome.
  I know the same thing happens to FoxPro apps too. Is this a PowerBuilder thing?
 Anyway... ideas?
 --Steve       http://www. ehomecreations.com
          Steve,
           | Posted: April 06 2007 at 15:51 | IP Logged |   |
 PowerHome has several built-in functions that may help.
 ph_handle() returns the handle of the main PowerHome frame window.
 ph_setforegroundwindow will set a particular handle to be the foreground window.  You could bring PowerHome to the foreground with: ph_setforegroundwindow(ph_handle())
 You may also want to look at the ph_windowstate function as well.
 All of these functions are callable using the socket server or through a plugin.
 Concerning your specific problem though...the title of the PowerHome window is " PowerHome  " with a single space in front and two spaces after.
          Thanks for the info!
           | Posted: April 06 2007 at 16:08 | IP Logged |   |
 That was it. " PowerHome "  with the spaces worked great.
 My VBA function is:
 '--- shells or finds a application
 dim sadStartsWith: sadStartsWith = 0
 dim sadContains: sadContains = 1
 dim sadMatches: sadMatches = 2
 Dim sPrgCation,sPathAndFile, nFindWinBy
 nFindWinBy = sadStartsWith
 sPathAndFile = "C:\Program Files\powerhome\pwrhome.exe"
 sPrgCation = " powerhome  "
 g_oGbl.EH_AppActivate sPrgCation,sPathAndFile, nFindWinBy
 Now all works GREAT!
