        | jeremybe Newbie
          Hi-
           | Posted: April 06 2007 at 13:57 | IP Logged |   |
 |  Can someone give me some guidance on writing an If then statement for a macro- I'm looking for a statement that would let me check the status of 3 insteon devices, if these 3 devices are off a variable is set to off, otherwise the variable is set to on
 Thanks for the help!
 I'm still on a quest for my perfect KPL solution...
        | TonyNo Moderator Group
          This will return "Off" or "On"...
           | Posted: April 06 2007 at 16:17 | IP Logged |   |
 if( ph_getinsteonstat( s1 )=1 and ph_getinsteonstat( s2 )=1 and ph_getinsteonstat( s3 )=1, "Off", "On")
 Where s1, s2, and s3 are your device ID's.
        | jeremybe Newbie
           | Posted: April 09 2007 at 12:04 | IP Logged |   |
 Tony, thanks - How do I actually get that on/off into a variable??? I'm looking for logic that will say if device x or device y or device z is on then set status=on else status=off - I'm then looking to trigger a PLC group change based on that status...
          Assuming your Global Variable (GV) is STATUS, just put this in your macro...
           | Posted: April 09 2007 at 12:26 | IP Logged |   |
 Set Global | STATUS | if( ph_getinsteonstat( s1 )=1 and ph_getinsteonstat( s2 )=1 and ph_getinsteonstat( s3 )=1, "Off", "On")
 You would then just create a trigger that fires when your GV changes to send your group command. I'll detail this tonight, if necessary.
 Edited by TonyNo - April 09 2007 at 12:36
        | jeremybe Newbie
          Tony I've been trying to do this, but I'm not getting it right...
           | Posted: April 16 2007 at 19:26 | IP Logged |   |
 I did the following in triggers:
 Action Type:Raw Formula
 Action:Set Global({LIGHT_STATUS} if( ph_getinsteonstat( "BSMNT-MEDIA ROOM" )=1 and ph_getinsteonstat( "BSMNTT-STAIRS-UP" )=1 and ph_getinsteonstat( "BSMNT-OVERHEAD" )=1, "1", "0"))
 Action Syle:Queued
 Status:Active
 Trigger Type:Insteon Change
 Trigger ID: PLC
 Trigger ID number:253 (I want my PLC group to trigger this)
 Trigger Value:ANY
 So I obviously did something wrong - If you could help me out with this and teh PLC trigger I'd appreciate it - I'm struggling ut trying..
