| Posted: August 03 2003 at 21:00 | IP Logged
Wow!! That is an old version. The error message you are getting is most likely due to you launching the upgrade utility from a folder named "PowerHome". The upgrade utility searches for any open windows labeled "PowerHome" and assumes that PowerHome is currently running. Try launching the upgrade utility by clicking on the "Start" button and selecting "Run...". This should get you past the "PowerHome is already running" message.
If this still doesnt work...you have two options. You can install the new version and start from scratch. Just email me your new reg number and I'll send you the unlock key. Or...you can email me your current database file and I'll manually upgrade it for you if you don't want to lose any of your setup.
Since you are upgrading from an older database, be sure and read the upgrade notes for any manual changes you may have to make.
Let me know how it goes and what I can do to help you.
