mustangcoupe Super User
Posted: March 06 2007 at 18:51 | IP Logged
I am still having problems with my insteon KPL. It functions correctly but If I go to the KPL screen then it does not show up. I have tried to reverify devices and it still didnt show up in the screen. BUT it does function from PH.
ALSO:
PH sees my control link as x10 communications and not as insteon. Anyone have experance or problems with these?
HA newbie
PowerHome - UPB - ELK
Posted: March 06 2007 at 20:21 | IP Logged
Todd,
Open the Insteon Explorer and go to the "Types" tab. Find all the lines that KeypadLinc lines and make sure that there is a check in the "KeypadLinc" column. Save / Refresh the changes and close / reopen the Insteon Explorer. Your KPL's should now show on the KPL Config tab.
If your ControLinc is sending X10 commands, then it will probably be easiest to perform a factory reset on it (check the SmartHome docs). After the factory reset, then use the "Rebuild" option on the "Links" tab to reprogram the links back into the ControLinc.
You can remove the X10 commands using some manual key presses on the ControLinc (check the SmartHome docs again), but the factory reset, would be cleaner.
PowerHome does not setup or remove X10 codes on the ControLinc but will see and respond to them if the ControLinc is programed to use them.
Posted: March 06 2007 at 20:51 | IP Logged
OK, Dave, got the KPL to show up in the list but I get error reading data from keypadlinc please try agian.
But I beleive I have a communications problem... I noticed all my links show flagged create. I think I am going to try and reboot the computer and PLC. Even though I can control the switches from the computer
Edited by mustangcoupe - March 06 2007 at 20:51
HA newbie
fetzervalve Newbie
Posted: July 26 2008 at 08:13 | IP Logged
I'm having the same problem. All of the KPLs are checked in the Types tab. I can control the KPL with the manual control in PH, so they are communicating.
