cmhardwick Senior Member
Posted: February 20 2007 at 16:38 | IP Logged
Is there a TempID used specifically to pass on the device ID from an insteon change trigger? I want to pass this along to a macro whenever a device changes status.
Actually, is there a table for insteon trigger temp variables, like there is for other triggers in the manual?
Edited by cmhardwick - February 20 2007 at 16:41
Posted: February 20 2007 at 17:25 | IP Logged
See Dave's reply to my Insteon Trigger Request....
Steve
Posted: December 18 2006 at 12:28 | IP Logged
Steve,
I can look into the additional triggers but I need to be careful not to add too many different checks otherwise speed may become an issue.
Not sure if Ive documented it elsewhere, but the new Insteon Device Chg trigger includes addtional supporting info in the TEMP variables that may assist you in your efforts (most triggers include addl info in the TEMP vars).
Below is the data that is contained in the TEMP vars for the Insteon Device Chg trigger:
TEMP1 ID of Trigger
TEMP2 0
TEMP3 Insteon CMD 2
TEMP4 Type of trigger
1 = Direct Command from PH PLC
2 = Group Cleanup from PH PLC
3 = Group Broadcast from PH PLC
4 = Direct Command from device
5 = Group Broadcast from device
6 = Group Cleanup from device
TEMP5 The address of the sending device
TEMP6 20 = Direct type command
21 = Broadcast type command
TEMP7 The address of the receiving device
TEMP8 The Group number for group type commands, 1 otherwise
TEMP9 Insteon CMD 1
TEMP10 ID of Receiving device
You can effectively get your "Level Change" trigger by using the "Insteon Device Chg" trigger with [Any] group and [Any] command and then placing this formula in the "Boolean" field:
case([TEMP9] when 21,22,24 then 1 else 0)
This will only allow the trigger to fire when a dim, bright, or stop manual change command affects the desired device. You could then create multiple "Insteon Device Chg" triggers with appropriate formulas in the "Boolean" field all executing different macros to pick up some granularity.
Posted: February 20 2007 at 18:59 | IP Logged
Thanks!! Now to experiment. I'm trying to end up with ONE trigger and a long macro to handle everything
Posted: February 20 2007 at 19:25 | IP Logged
Drat. That helps as long as the change isn't instigate by PH. Otherwise, the Sending (TEMP5) and receiving (TEMP7) are both the powerlinc. For now I'll jut have to work with individual triggers for each unit.
Hopefully the changes Dave is working on will address this.
Thanks again Smarty!
