           | Posted: May 30 2022 at 10:17 | IP Logged
Can the Installation Directory of "C:powerhome: be
 changed to a different location?  Can't seem to find any
 way to do so.
 My hard drive holds a Backup folder in addition to all
 the other stuff.  For ease of regular auto-backup I would
 like to put the powerhome directory into the backup
 folder.  EG, "C:\Backup\powerhome"
 Otherwise, I end up with two copies.... the original
 working copy and the daily backup copy moved weekly to
 another drive.
  Edited by GadgetGuy - May 30 2022 at 10:18
           | Posted: May 30 2022 at 13:09 | IP Logged
This is what I use for a local backup to a second drive (Q
 drive) that is within the Box PH is running on:
 if(ph_backupdb("Q:\PH-Backup\pwrhome" +  ph_replaceall(string(date(today())),"/","-")+".bak",1)=0,ph_ usermessage("Q Drive
 BackUp OK"),ph_macroparm( "ANNOUNCE", "Error while writing backup file locally.", 1, "announce.wav", 1.5,"set80") +
 ph_usermessage("Q Drive BackUp NOT OK"))
 I would think what you want to do is surely possible.
  Edited by smarty - May 30 2022 at 13:13
           | Posted: May 30 2022 at 13:29 | IP Logged
I know that I didn’t answer your question… but moving PH to a “non-
 standard” location (something other that c:\powerhome\  is likely just asking
 for additional unforeseen problems…just guessing.
 In my approach, I am only backing up the .db file.  Everything else is quickly
 and easily reinstalled if need be.  Sorry I am not more help.
           | Posted: May 30 2022 at 13:40 | IP Logged
Smarty-
 Thanks for the reply.
 I do back up ph every night to my Backup folder on the
 hard drive using ph_backupdb().
 In addition, I want to back up the same computer hard
 drive every night to an external drive as that folder
 also contains the daily backup files of all our home
 computers.
 This Backup files also include the c:powerhome folder
 folder as there is more than the ph database that changes
 everyday.  I want to capture all ph changes that occur
 like web html files, added image file changes, or their
 updates.  To do so, if I can put everything in a single
 Backup file to be copied elsewhere every night, it makes
 things easier.
 I can do it without that but it takes more effort and
 coordination, so just hoping to simplify.
 I hoped the ph dir4ectory location might be in the .ini
 file but I don't see it, or any other appropriate fie.
