         jeffw_00 Super User
           | Posted: September 19 2021 at 16:47 | IP Logged
Hi Dave - I am seeing repeatable communication issues with the
 new release that never happened with the old one.  I'm wondering if
 some timeout or other parameters have changed.  I've uploaded a
 log excerpt and marked the worrisome sections.  These are issues
 that don't occur with the old release (ever) and have repeated 3 or
 4 times in the last couple of hours since I switched over. (i've since
 switched back).  Any/all advice appreciated. I'm using a Serial PLM
 if that helps.
 2021-
 09-19_164718_commprob.txt
  Edited by jeffw_00 - September 19 2021 at 17:17
         jeffw_00 Super User
           | Posted: September 19 2021 at 16:52 | IP Logged
related question - I have a 2 powerhome folders on my C drive - one
 with 2.2 and one with 2.1.5.  Since my C drive is an SSD I also have 2
 such folders on my D (regular HDD) drive that hold powerhome.db.
 Right now, when I swap versions I swap both folders (via rename).
 But I think that when I swap from 2.1.5 to 2.2, I could also (after
 copying it) leave the old D drive folder with the 2.1.5 database init and
 just run PHUPG again before firing up 2.2  - true?
           | Posted: September 20 2021 at 23:43 | IP Logged
Jeff,
 Concerning your log...the line below is a problem:
 Communication problem (No Response) with Insteon controller PLMMODEM detected.  Attempting to restart controller (1 of 5)...
 I'll need to trace the code to see what causes this problem. The following errors associated with the macro are probably the result of the
 insteon controller not being fully restarted. I'll probably need to make some changes where a controller restart doesnt go through the database
 discovery again (like it does on startup and required a delay in your macro). I'll probably need a flag as well so that functions return a
 specific value when a command to the controller is sent when the controller is not fully started.
 The next highlighted block with the line:
 Incoming Insteon received on INSTEON PLM controller PLMMODEM. From Address:[48.6C.A8] To Address:[13.00.01] Flags:[199] Cmd1:[6] Cmd2:[0].
 Decode: Group Broadcast Success/Failure Report.
 This is not an error. This is just logging a new type of error message that Insteon sends. In the previous version of PowerHome, you would have
 gotten a log entry but it would have said something like unknown command. This command is sent when an Insteon device is manually controlled
 (that is linked to other Insteon devices). The Insteon device first sends out a grYou are oup broadcast followed by group cleanup commands.
 After the group cleanup commands the group broadcast success/failure command is sent. In this particular line, the GARAGESW was manually
 controlled, it sent the group broadcast followed by group cleanups. A group cleanup is an acknowledged command and if a device is not actually
 acknowledged, this command will report that. So not an error or anything but a normal Insteon command that comes in that is logged with the
 correct description vs the previous unknown command nomenclature.
 Concerning your question of versions...If the new version is installed in c:\powerhome and the previous version is in something like
 c:\powerhome_215, you wouldnt necessarily need to rename folders to switch between versions. Just update the appropriate pwrhome.ini to point to
 the proper database location. So the pwrhome.ini file c:\powerhome_215 might have the database at d:\powerhome_215\database. Unless you're
 specifically doing something in your PowerHome code that is specifying a directory path, this should work for you to quickly switch back and
 forth.
 You are correct concerning the database. If you've switched back to 2.1.5 and that database is more current and you want to try 2.2 again, you
 can just copy your 2.1.5 database to the 2.2 directory and run the PHUPG on it so your 2.2 testing will have the latest data. Just be careful
 you don't update your only copy of 2.1.5 as you cant go backwards.
 I'll let you know what I find out concerning the controller restart.
         jeffw_00 Super User
           | Posted: September 21 2021 at 07:42 | IP Logged
Hi Dave - thanks so much for getting back to me and for the
 thorough explanations and answers.  I think you're saying that the
 problem I'm seeing is that some sort of "Communication Problem"
 is triggering a restart, and in 2.2 (unlike 2.1.5) that restart
 "distracts" (for lack of a better word) PH so that some  subsequent
 commands don't happen properly.  What I wonder (and I can look if
 you tell me what to look for) is whether I also get the
 "Communication Problem" with the older code but it just causes no
 adverse effect, or whether I get the Communication Problem with
 only the newer code.  If the latter, I hope your proposed fix will be
 sufficient, but wonder whether I need to root cause why I'm getting
 the Communication Problem at all.  One theory I had is that
 perhaps I'm an outlier in that I use a PLM with a serial (as opposed
 to USB) interface?    Anyway, -many- thanks for looking into this.
 Let me know what else I can do to help.  Standing by :-)
           | Posted: September 22 2021 at 23:17 | IP Logged
Jeff,
 Yes, your summation is correct. Im pretty sure the previous version of PowerHome had the communication problem detection but it would
 have done a restart and then been done almost instantly. The current version rescans the whole PLM database is which is the cause of
 your current problem. You can search the log to see if you had any restarts with 2.1.5 and they should show but it's possible that the
 newer code in 2.2 is using different criteria to signify a communication problem. I will need to review that whole section of code to
 know for sure.
 Serial vs USB shouldnt make a difference. Actually, I prefer the straight serial as they are definitely more stable. The USB and
 Serial PLM's use the same code and are communicated with as a serial port with the USB creating a virtual serial port that PowerHome
 connects to so an extra layer of potential problems with the USB device.
 I'll let you know what I find out after Ive been able to go through the code.
         jeffw_00 Super User
           | Posted: September 23 2021 at 07:47 | IP Logged
Hi Dave - FWIW - I searched my 2.1.5 log for (case-insensitive)
 "communication problem" and "no response"  and found nothing in the
 past 2 weeks (excluding the short periods I was running .2.2 - less
 than several hours).  So yeah - something in 2.2 is detecting an issue
 where 2.1.5 doesn't.
 I've been on 2.1.5 this long, I can stay on it longer :-).  Thanks in
 advance for anything you can do,
           | Posted: September 24 2021 at 21:44 | IP Logged
Jeff,
 Ive added it to my notes to look into this to see what might be different between 2.1.5 and 2.2.
         jeffw_00 Super User
           | Posted: September 25 2021 at 07:46 | IP Logged
No problem. . Patiently standing by
         jeffw_00 Super User
           | Posted: November 21 2021 at 09:26 | IP Logged
H Dave - any update here?  Thanks!
         jeffw_00 Super User
           | Posted: March 29 2022 at 08:02 | IP Logged
Hi Dave - any update here?   I'd really like to upgrade at some point :-)
         jeffw_00 Super User
           | Posted: April 10 2022 at 13:16 | IP Logged
Perhaps you can add an option to disable the rescan on restart.
           | Posted: July 03 2022 at 22:38 | IP Logged
I too am having more down time than up time due to many
 communications errors. It can easily be duplicated by
 plugging in an invalid comport number. PH locks itself
 into an endless nightmare of error recovery. I don't have
 bad memory as in Kens nightmare. I'm going back and see
 what I did wrong, or Dave, to something of stability.
 After that I'll investigate what happen and gather more
 documentation. The problem as I see it is that PH loses
 its way and gets mired down in muddles of errors. It is
 in general as not as specify to a particular problem.
 Sorry Jeff didn't mean to hijack your thread. Just
 thought it would be simpler to add my comments
 rather than reinvent the wheel.
 Pete...
         jeffw_00 Super User
           | Posted: July 04 2022 at 07:37 | IP Logged
No problem Beachbum.  With the latest patch I'm seeing the
 messages rarely - and it's not impacting operation.  It seems to
 happen when I have a macro that has insteon commands separated
 by hundreds of milliseconds (i.e. using DELAY).   If you don't have the
 latest patch you should try it.
