         jeffw_00 Super User
           | Posted: August 25 2021 at 20:07 | IP Logged
I have an IOLinc - that senses garage door open and close.  The
 open  triggers a LOT of Insteon traffic (as it triggers other macros)
 such that it appears the close signal  sent from the IOlinc doesn't
 always fully get through.  Normally I trigger based the "off" and "on"
 received from the IO linc - but as a backup I would also like to
 trigger off the Broadcast Group Success/Fail message (see below)
 but I don't know how to detect it.  Does anyone? Thanks!
   Incoming Insteon received on INSTEON  PLM controller
 PLMMODEM. From Address:[50.4C.C3] To Address:
 [11.00.01] Flags:[195] Cmd1:[6] Cmd2:[0].  Decode: Group
 Broadcast.  From: GDOORIO Group: 1, Grp Brdcast  Success/Fail
     615       Insteon  In     0
  Edited by jeffw_00 - August 27 2021 at 20:08
           | Posted: August 28 2021 at 00:15 | IP Logged
Jeff,
 You should be able to setup a trigger for
 "Insteon Group In", "GDOORIO", 1, "Grp Brdcast Success/Fail"
         jeffw_00 Super User
           | Posted: August 28 2021 at 07:35 | IP Logged
Hi Dave - "Grp Brdcast Success/Fail" is not in the dropdown for
 Trigger Value - what am I missing?
           | Posted: August 29 2021 at 18:17 | IP Logged
Jeff,
 What version of PowerHome are you running? This option did not appear until the 2.2beta versions.
         jeffw_00 Super User
           | Posted: August 30 2021 at 07:20 | IP Logged
ah - 2.1.5d - sorry - I'll look into updating this weekend.
