         kkomara Newbie
           | Posted: December 17 2020 at 10:21 | IP Logged
I have PH installed in Ubuntu using WINE.  Works really well - but I have a weird issue when I am trying to create/edit macros.  When I am trying to edit the formula in a macro - the "(" and the ")" do not work !!!  When I am in the Formula Builder - when I type "ph_" I get the pop up box with the various options.  When I choose for example "ph_insteonwithret" I get "ph_insteonwithret" on the screen.  When I try to type the "(" - so that I would have "ph_insteonwithret(" which SHOULD bring up another pop up box with more options) - I cannot type the "(" - just stays blank.  I cannot type the ")" either.  Its like the "(" and the ")" are not defined in my Linux keyboard - but both of those keys actually work fine in say a simple Text editor.  I have installed same version of PH on a real Windows 10 PC - and this works fine.  In fact this worked fine on my PH 2.1b install in WINE that I was using for > 4 years.
 Anyone have any ideas ??
  __________________ Kevin Komara
           | Posted: December 20 2020 at 18:20 | IP Logged
Kevin,
 That is indeed odd. Not sure why it wouldnt work in 2.2beta3-3. The editor controls uses the open source Scintilla control to handle
 the "editor" aspects. It's possible that 2.1b used a different version of Scintilla that 2.2beta3-3 but I would have to dig through
 the sourcecode to see if that is the case.
 One thing I would try and see if you encounter the problem while using an onscreen keyboard (assuming such an option exists in WINE).
 The other thing I would try is typing out the formula in a separate editor and copy/pasting into the PowerHome formula editor.
 The popup you refer to that appears after typing the "(" can also be brought up by pressing the "F2" button. You can type the function
 name, press "F2" and see if that has something to do with keeping the control from recognizing the "(" and ")" keystrokes.
 Let me know,
         kkomara Newbie
           | Posted: December 26 2020 at 17:02 | IP Logged
 So the "(" and ")" when editing a formula do not work with the Linux on-screen keyboard either.  But the F2 does bring up the pop up.  I can cut and paste the "(" or ")" and I have been using cut and past for entire commands for days.
 I can use the "(" and ")" in a normal text editor in Linux - so I can only assume the event that happens when the ( or ) in PH is just not firing in Linux/Wine.
 Bummer becuase it is pretty hard to edit macros and formulas without the ( or ) !!!
 Any ideas ?
         kkomara Newbie
           | Posted: January 01 2021 at 12:57 | IP Logged
Hey Dave,
 Any thoughts on how to fix my issues with no "(" or ")" when PH running under Ubuntu Linux/WINE ???  I have been getting around it using copy and paste.... but that is a pretty big pain !!
 Kev
           | Posted: January 04 2021 at 18:30 | IP Logged
Kevin,
 One other thing to try is typing the formula in the Multi-Editor in a different "mode" than PH Formula. When you open the editor window to edit
 or create a new formula, try pressing shift+f5 (SQL Mode) and see if the ( and ) characters work in there (other modes don't have special
 processing for parenthesis). If that doesnt work, give each of the other modes a shot as well (shift+f1 thru shift+f6). If none of those work,
 then the problem will be with Scintilla and may not be fixable. If another mode does work, then that narrows it down and I can see if there is
 any options I may have to solve it from within code.
 Also, in the macro formula (or any other formula field), try NOT opening the editor and see if it allows you to type the parenthesis characters
 directly in the editable field. That will tell me if it's a PowerBuilder related issue or not. If you cant type the ( and ) characters just in
 the editable field, then there won't be anything I can do other than wait for a new version of PowerBuilder to upgrade to and see if it's fixed
 there.
 Let me know,
