         ccrider Newbie
           | Posted: July 01 2018 at 14:13 | IP Logged
I realize PowerHome, by it's very spelling, will be an upgrade+++ from the old, yet still fairly reliable DOS based ES1400e; I've used for eons. But can it 'reach back' and use simple commands via similar logic questions? i.e. IF AND OR THEN WHENEVER ON OFF DIM BRI..., or do I have to rethink my way through the whole process? I guess what I'm asking is; how much of a learning curve (relearning) am I looking at?
 I'm really happy with the system I have in it's present state, but sometimes drool over the abilities of Insteon.
 Thanks for any advice from those that have been down this path.
  __________________ ES-1400e; yes that old...
           | Posted: July 02 2018 at 10:16 | IP Logged
ccrider,
 Welcome to PowerHome.
 Ive been playing with automation for a long time (as far back as 1985) and I have never heard of the Enerlogic ES1400e. A quick Google looks like it
 was an X10 system around the 1993 era...pretty old  .
 I couldnt find out what the exact capabilities are but I wouldnt think PowerHome would be too much of a learning curve if you're working with a DOS
 based system with IF THEN programming capabilities. The PowerHome macros have full if/then capability and are fairly easy to pick up relatively
 quick. Formulas get a little more involved but have alot of power. You can also just use VBA if youre familiar with Visual Basic.
 Since the 30 day trial is fully unencumbered, I would just give it a try and see if its to your liking. PowerHome definitely appeals to the more
 technical types but there are plenty of non-programmers making good use of it.  Just make sure that PowerHome supports whatever hardware you
 currently have so you can get a feel for it. Even if it doesnt, PowerHome supports a "Virtual" controller so you can at least play with it and see
 if the programming capabilities are within your limits.
