jeffw_00 Super User
Posted: January 14 2017 at 15:49 | IP Logged
Hi - I have created a tab in the Control Center which I access remotely around my house using the Silk Browser on the Amazon Fire. (so the Fire is a $33 touch-screen panel :-) ).
My question is this - Every 15 minutes, Powerhome queries the web for the local temperature, and updates a Global Variable. I use this to decide whether to turn certain things (heaters, ceiling fans) on and off, and I also display the value on the Control Center tab as a Static GlobalVar.
However, updating this the global variable in PH does not update the displayed value on the remote browser. To see the current value I have to refresh the page at the browser. Is there any way I can "Push" the update of the global variable to the browser screen so that PH controls when the screen updates?
If not - as a plan B, maybe I can use an "Action GlobalVar", with an null action, and then pressing it will update it's value? [I can try this if it's my only option].
Posted: January 17 2017 at 11:47 | IP Logged
Jeff,
There is no way to effectively "push" the changes to your remote web based CC screen. This is something I would like to investigate more but it currently doesnt exist.
You could achieve the effect though by making a simple HTML webpage and placing it in the PowerHome web directory and call it from the Silk browser vs calling the CC
directly.
<html>
<head>
<script>setInterval(function(){var ifr=document.getElementsByName('main')[0];ifr.src = ifr.src;},300000);</script>
</head>
<body>
<iframe src="http://yourphserverip:8000/ph-cgi/controlcenter?id=YOUR CCID&type=4&flags=4" width="100%" height="100%" frameborder="0" name="main"></iframe>
</body>
</html>
Save the above code to CC.HTM in the PH web directory (make the necessary adjustments to the server IP and CC ID). The "300000" is how often the page will refresh in
milliseconds. In this case it should refresh every 5 minutes.
jeffw_00 Super User
Posted: January 18 2017 at 19:36 | IP Logged
Hi Dave - Could you (or anyone) briefly explain how I would construct a URL to access a file in the Powerhome Web directory.
THANKS!
Edited by jeffw_00 - January 18 2017 at 19:37
Posted: January 18 2017 at 19:40 | IP Logged
Should just be http://yourphserverip:8000/yourfile.ext
jeffw_00 Super User
Posted: January 18 2017 at 19:41 | IP Logged
Thanks Tony - will try it.
jeffw_00 Super User
Posted: February 19 2017 at 11:04 | IP Logged
if anyone's watching - it works better if you take the :8000 out of the HTML for some reason..
Thanks guys!
