pwmcmaho Newbie
Posted: January 25 2007 at 20:51 | IP Logged
I've downloaded a trial of PH to start playing with the Insteon support. I've read the directions on getting things setup, starting with a KPL and a few related switches in my kitchen (I have about 45 insteon devices). after setting up the PLC and manually entering in a few of the switches and the KPL, I hit F5 to do a refresh and grab the links... I can see from the PLC log that things are communicating, however it never stops. I let things got for a week (7 days!) and they never finished. The KPL was originally programmed via Houselinc, though it was/is not running whiles I have PH running... Thoughts on how I can diagnosis this one?
Patrick
Viper Groupie
Posted: January 25 2007 at 22:25 | IP Logged
Patrick,
Uncheck the Status Scan on the Insteon Explorer.
Posted: January 26 2007 at 07:22 | IP Logged
If the Status Scan is checked, it will always scan all Insteon devices to update their status. This can be turned off if you wish.
pwmcmaho Newbie
Posted: January 26 2007 at 15:17 | IP Logged
got it - thanks, guys!
Posted: January 26 2007 at 16:59 | IP Logged
Yep. If Status Scan is enabled, PowerHome will continuously poll the devices in the background while it's got nothing else to do. It does this in an attempt to discover any new links which may have been manually created.
