Subject Topic: No pending ops Post ReplyPost New Topic
MrGibbage
Posted: January 03 2007 at 23:29 | IP Logged Quote MrGibbage
Starting with PH 1.03.4.9. I was able to auto discover my devices, but I am not getting any pending operations. None of the links that I am creating/deleting/modifying are happening--they stay flagged. I changed the interval to 5 and tabbed out, but I still don't see anything happening. What am I missing?
Skip
ui:getplcstatus
PLC:getPLCstatus=beginlist
port=COM3
connected=True
firmware=2.13
id=05.03.A0
devicetype=InsteonPLC-COM
lastErrorMsg=#0:
endlist
uifinished:getplcstatus
ui:getlinks
uifinished:getlinks
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
Progress=12%,128,1024
downloadTimer started
timerActivate enabled
Progress=25%,256,1024
Progress=37%,384,1024
Progress=50%,512,1024
ProgressError=0%,512,1024
UI:ConnectedAndReady
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=11
PLC:eventraw=15
SDM:DM=active,1.01.122.278,1/3/2007 11:20:25 PM,responded,05.03.A0,2.13
starttime=00:09
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=15
PLC:eventraw=11
bad:06 len=5401
ProgressEnd=False
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
Progress=62%,640,1024
Progress=75%,768,1024
Progress=87%,896,1024
ProgressEnd=True
PLC:getlinks=beginlist
id=06.D3.E3,mode=sla,addr=FC70,laddr=0000,g=1,cmds=00 00,d=00
id=06.E7.E1,mode=sla,addr=FC78,laddr=0000,g=1,cmds=00 00,d=00
id=06.BF.CE,mode=sla,addr=FCC0,laddr=0000,g=1,cmds=00 00,d=00
id=07.49.B0,mode=sla,addr=FD38,laddr=0000,g=1,cmds=00 00,d=00
id=05.DE.A3,mode=sla,addr=FD70,laddr=0000,g=1,cmds=00 00,d=00
id=05.03.A0,mode=sla,addr=FD78,laddr=0000,g=1,cmds=00 00,d=00
id=04.24.8F,mode=sla,addr=FDC0,laddr=0000,g=1,cmds=00 00,d=00
id=07.3B.56,mode=sla,addr=FEA0,laddr=0000,g=1,cmds=00 00,d=00
id=06.D4.4C,mode=sla,addr=FEC8,laddr=0000,g=1,cmds=00 00,d=00
id=04.1C.3A,mode=sla,addr=FF10,laddr=0000,g=1,cmds=00 00,d=00
id=07.33.26,mode=sla,addr=FF60,laddr=0000,g=1,cmds=00 00,d=00
endlist
MrGibbage
Posted: January 03 2007 at 23:33 | IP Logged Quote MrGibbage
Oh, and yes, they are all flagged as active.
MrGibbage
Posted: January 04 2007 at 11:05 | IP Logged Quote MrGibbage
Looks like this thread may help. I'll give it a try when I get home tonight.
http://myx10.com/forum/forum_posts.asp?TID=964&PN=2
Skip
MrGibbage
Posted: January 05 2007 at 09:48 | IP Logged Quote MrGibbage
At the risk of making this the longest thread where only one person wrote anything, I have another question. I did get the Pending Operations problem fixed. I now have a working system. I would like to do one more thing though. First, I have an ELK system and am using the M1XSP to connect to the 2414S. I just disconnect the cable between the M1XSP and 2414S and connect the 2414S to my computer when I am managing my links. I do not have any KeyPad Lincs. But I would like to set up some different groups to make my rule writing easier for the Elk. So, can I store different group information in the 2414S? For instance, I would like the following groups:
INTERIOR
EXTERIOR
UPSTAIRS
DOWNSTAIRS
ALL_LIGHTS
WELCOME_HOME (these are the lights that I want to turn on when I come home)
As you can see, there will be lights that will belong to more than one group. Can I assign a particular light to more than one group? Can the groups be defined in the 2414S such that the ELK can reference them with its automation rules?
Regards,
Skip
Edited by MrGibbage - January 05 2007 at 09:49
cmhardwick
Posted: January 05 2007 at 10:07 | IP Logged Quote cmhardwick
As to the "lights in more than one group" yes. That's the beauty of Insteon and Powerhome.
As to "can the elk manipulate these groups" I'm not that familiar with that function, but I believe you just have to creat the groups in a particular range, as the Elk only uses part of the full 255 group range.
HTH!
Cicero, Enjoying automation!
MrGibbage
Posted: January 05 2007 at 14:59 | IP Logged Quote MrGibbage
Well, everything was going great, but then I think my database went screwy or something. I have links that forever say DELETING, FLAGGED CREATE, or CHECKING. No amount of rebuilding seems to fix it. I also noticed that the pending operations box doesn't show things like it used to. I remember that right after I start up PH, I was always seeing something going on up there, but now nothing.    I also see that some of the "button" fields have numbers like "-1004", where the rest of them show "1". Finally, I think that the SDM log is showing that nothing is really happening anymore either. I get the following logged, but then nothing else is ever added. Do I need to reset the 2414S? If so, how do I do that?
ui:getplcstatus
port=COM3
connected=True
firmware=2.13
id=05.03.A0
lastErrorMsg=#0:
endlist
ui:getlinks
uifinished:getlinks
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
ProgressError=0%,896,1024
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=11
PLC:eventraw=11
SDM:DM=active,1.01.138.308,1/5/2007 2:51:14 PM,responded,05.03.A0,2.13,xdevices=True
starttime=00:08
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=11
PLC:eventraw=15
PLC:eventraw=11
ProgressEnd=False
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
ProgressEnd=True
endlist
And that's it. Nothing else is ever added beyond this point. Everything was going great. What happened?
Regards,
Skip
MrGibbage
Posted: January 07 2007 at 13:06 | IP Logged Quote MrGibbage
Well, two days now and I don't seem to have any progress. I've ordered a new PLC, which should be here tomorrow or tuesday. It's strange that everything was going good with PH--I was adding and deleting links and groups, and then all of a sudden, the PLC stopped responding. I really hope that PH didn't break my PLC, because I want to use it to manage my links. Smarthome doesn't like supporting the 2414S--they said that it was meant for their own interenal development, but the community started screaming for it. Bottom line is, the really won't tell you anything over the phone about troubleshooting it.
Here, I tried uploading the timercoreapp using the salad downloader. Funny thing is, SALad reports success, but the SDM says differently.
SDM:DM=active,1.00.116.116,1/7/2007 12:51:51 PM,responded,05.03.A0,2.13
ui:0001:0001:port=?
PLC:disconnect=OK
PLC:0001:0001:port=true
ui:0001:0002:getport=
PLC:0001:0002:getport=COM3
ui:0001:0003:getWebSALadDownloadList=
PLC:0001:0003:getWebSALadDownloadList=beginlist
Core Application,coreApp.slb,coreApp.html,1.00,8/24/2005 4:00:00 PM,Smarthome
CLEAR Core Application,clearCoreApp.slb,clearCoreApp.html,1.00,8/24/200 5 4:00:00 PM,Smarthome
HDK SALad Application,HDK.slb,HDK.html
Timer Core Application 1.06,timerCoreApp06.slb,timerCoreApp.html,1.06,12/19/2005 4:15:00 PM,Smarthome
endlist
ui:0001:0004:isresponding=
PLC:0001:0004:isresponding=True
ui:0001:0005:downloadSALadFile=C:\Program Files\Smarthome\SALad Downloader\timerCoreApp06.slb
PLC:0001:0005:ERROR=012:MapNotLoaded-PLC not connected or no valid map. Try using isResponding first.
PLC:0001:0005:downloadSALadFile=-7
ui:0001:0006:isresponding=
PLC:0001:0006:isresponding=True
ui:0001:0007:downloadSALadFile=C:\Program Files\Smarthome\SALad Downloader\clearCoreApp.slb
PLC:0001:0007:ERROR=012:MapNotLoaded-PLC not connected or no valid map. Try using isResponding first.
PLC:0001:0007:downloadSALadFile=-7
I googled "error=012" and mapnotloaded, which gave exactly two hits, neither of which was terribly useful.
I'm looking for ideas here.
Skip
Posted: January 07 2007 at 15:43 | IP Logged Quote TonyNo
Maybe a dumb question, but have you tried unplugging it for a bit?
MrGibbage
Posted: January 07 2007 at 16:15 | IP Logged Quote MrGibbage
I left it unplugged overnight. I've pressed the reset button until my fingers turned blue. I did it with it plugged in, unplugged, while plugging and while unplugging. I also help it in while the moon was full, but that didn't matter either. I think it's fried. I just don't know why.
Skip
Posted: January 08 2007 at 01:15 | IP Logged Quote dhoward
Skip,
I doubt the problem is with your PLC. Normally only two things will keep operations from showing in the pending ops window...not being flagged active (which you've already said they are) and being flagged as COMM Failed. You can check both in the "Device Maint" tab of the Insteon Explorer. If they are flagged as COMM failed, that column will appear with a reddish background.
The only other things that will keep operations out of the Pending window is the controller not being active (such as the PLC actually failed or the Insteon DM not configured in the Explorer) or Poll Interval set to 0 or all of the checkboxes in the Insteon Explorer unchecked (in this last case, create or delete links should still show up).
Check these and let me know,
MrGibbage
Posted: January 08 2007 at 07:01 | IP Logged Quote MrGibbage
Device Maint tab shows every device in my network as comm failed except my PLC (that is, they show the reddish background). I would say that it is a statistical impossiblity that every device in my network would fail at the same time except the PLC. Kinda reminds me of when I was marching in formation at my boot camp graduation and my dad commented that I was the only person that was in step :)
If they are flagged as comm failed, should I check the box? What does comm failed mean? What does checking that box do?
Skip
MrGibbage
Posted: January 08 2007 at 07:04 | IP Logged Quote MrGibbage
Look at the SDM log I got from today:
ui:getplcstatus
port=COM3
connected=True
firmware=2.13
id=05.03.A0
lastErrorMsg=#0:
endlist
ui:getlinks
uifinished:getlinks
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
ProgressError=0%,768,1024
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=11
PLC:eventraw=15
SDM:DM=active,1.01.138.308,1/8/2007 6:56:39 AM,responded,05.03.A0,2.13,xdevices=True
starttime=00:08
bad:02 len=585
bad:02 len=17686
PLC:eventraw=12
PLC:eventraw=11
PLC:eventraw=11
bad:15 len=5401
PLC:eventraw=11
ProgressEnd=False
ProgressStart
ProgressMax=1024
Progress=0%,0,1024
ProgressEnd=True
PLC:getlinks=false,failed due to corrupted database
Posted: January 08 2007 at 07:38 | IP Logged Quote TonyNo
The quick answer is to check the red boxes. That will clear the errors and get you going again. You may also want to increase the number of failures parameter as several have done.
MrGibbage
Posted: January 08 2007 at 20:14 | IP Logged Quote MrGibbage
OK. I checked the red boxes and what do you know? It started queuing up the pending ops again. I finished creating all of my links and I'm really thinking that it's gonna work. I hook up the PLC back to the Elk again and test some groups. Guess what. None work. I restart PowerHome again, and I still get the same message from the SDM at the end: PLC:getlinks=false,failed due to corrupted database. Now, I've tried resetting the PLC for a few days now, so I figured by now I probably need to reload the TimeCoreApp, so I fire up SALad and I still get the ERROR:012 message. Oh well, my new PLC should be here in the next day or two. *sigh*
MrGibbage
Posted: January 14 2007 at 14:08 | IP Logged Quote MrGibbage
SOLVED
Replacing the PLC fixed it.
Skip
