PowerHome Macros, Scripts, and Formulas Repository
 PowerHome Messageboard : PowerHome Macros, Scripts, and Formulas Repository
Subject Topic: DIMAC Macro Post ReplyPost New Topic
Posted: December 20 2006 at 21:20 | IP Logged Quote TonyNo
DIMAC is a macro that accepts an address/ID and a dim level in two TEMP variables and dims the associated device. This is used in a few of my other examples.
TEMP1
Address/ID (i.e. "B5" or "PORCH LAMP")
For Insteon devices, add an "I " to the ID ("I PORCH LAMP")
TEMP2
Dim level percentage (i.e. "75")
linky
Here is a JavaScript function that you can put in a web page to call this.
function dimac(ad, value)
{ document.execsendkeys.sendkeys.value = "ph_rtne( ph_setvar_s( 2, 1, '" + ad.toUpperCase() + "') + ph_setvar_s(2, 2, '"+ value + "') + ph_macro('DIMAC'))"; document.execsendkeys.submit(); }
martlist
Posted: July 18 2007 at 00:58 | IP Logged Quote martlist
just trying to setup a slider page like your example and so first step was to import the macro. Never doen this stuff before so may be doing it wrong. Followed the forum post on how to import and get the folling on execute:
Invalid Direct SQL Code -193
     SQLSTATE = 23000
[Sybase][ODBC Driver][Adaptive Server Anywhere]Integrity constraint violation: Primary key for table 'macroheader' is not unique
Back to Top View martlist's Profile Search for other posts by martlist
Posted: July 18 2007 at 07:15 | IP Logged Quote TonyNo
It looks like you already had a macro called DIMAC when importing. Try deleting it and then importing again.
