A.P.B Newbie
Posted: October 29 2005 at 12:37 | IP Logged
I'm trying to install powerhome on to an old 486 laptop running windows 98. I've installed the runtime files (PH_1032.exe) but when I run ph10343full.exe it comes up with the error message
1155 File c:\test\instmisa.exe not found then exits, any suggestions
Allan
krommetje Super User
Posted: November 04 2005 at 22:26 | IP Logged
This means that Microsoft Installer Package hasn't been installed on your machine... setup needs the microsoft installer to setup PH
just a note: upgrade to IE 5.5... I found that if you use IE4 or below 5.5 you could have more errors than you'd wish for... also be sure to run y2k.exe if this hasn't been done...
goodluck!
Peter
Posted: November 06 2005 at 19:17 | IP Logged
APB,
Did this get resolved for you?
As a side note, if you are installing version 1.03.4.3 (ph10343full.exe), then you don't need ph1032.exe. Everything should be included in the ph10343full.exe except for the Microsoft Installer Package as Peter pointed out. I used to include it in the install, but it seemed kind of unneccessary since it's ususally already installed on most Windows installations. However, phrt_1032.exe definately includes the Windows installer.
Let me know if you still need help,
