           | Posted: November 26 2003 at 11:18 | IP Logged |   |
 |  Tony, Not really...I did a search of Dejanews however and did turn up the following code snippet: set oComPort  CreateObject("MSCommLib.MSComm")' Set Com 3
 oComPort.CommPort  3
 ' 9600 baud, no parity, 8 data, and 1 stop bit.
 oComPort.Settings  "9600,N,8,1"
 ' Tell the control to read entire buffer when Input is used.
 oComPort.InputLen  0
 ' Open the port
 oComPort.PortOpen  True
 ' Send a command
 oComPort.Output  "ATL1" & vbCr
 ' Wait for response - (Could use a loop here)
 WScript.Sleep 2000
 ' Read response
 Wscript.Echo oComPort.Input
 ' Close the port
 oComPort.PortOpen  False
 Dave   |
