          Peter,
           | Posted: January 27 2005 at 09:51 | IP Logged |   |
 In the PowerHome status screen, each of the status windows can be adjusted for size and position by the user.  If the eventlog and waiting macros screens are not showing enough info, then you can resize them if you like.  Once you've got the sizes and positions to your liking, you can then right-click and select "Save" from the popup menu and the status screen will remember your settings.
 There is also a setting in the pwrhome.ini file that can be adjusted as well for the number of eventlog rows displayed on the status screen.  Look under the [PowerHome Status] section and change the "eventlogrows" setting to the number of rows that you would like.
