           | Posted: April 11 2004 at 11:00 | IP Logged |   |
 |  As I have assumed from your comments, this would only work on items controlled by PH (not directly as with a switch). Create a new Global, say, LightEnable.  You would then create a macro, or, timed event to set/clear this flag, then, add a line to check this before you turn it on in a macro, or, trigger. Timed Eventat 7am, clear flag (LightEnable=0)
 at 7pm, set flag (LightEnable=1)
 Old Light MacroLight On
 New Light Macroif( {LightEnable} = 1, 1, 999)
 Light On
 For a trigger, simply add this to the Boolean column... if( {LightEnable} = 1, 1, 0)
