        | GadgetGuy Super User
          I read somewhere in a post herein that a reliable way to
           | Posted: May 16 2013 at 19:38 | IP Logged |   |
 |  trigger from a switchtap was to create a Virtual Device
 and link it to the switch.
 Then make all the Triggers fire against the Virtual
 Device.
 I have done that, and linked the Virtual Dvc and switch
 together, but changes to neither one cause corresponding
 changes to the other.
 Worse, If I test the Virtual Dvc with a
| Code:
       | ph_getinsteonlevel ( "DWN STR MONITOR" ) |  |  |
 function [where DWN STR MONITOR is the Virtual Device] I
 always get a "0" returned no matter what the state of the
 Real Dvc is as show in the Device Status Window.
 Any ideas, or thoughts? I thought a Virtual Device was
 supposed to track the state of its linked counterpart. Or
 in the Quantum sense, that they were 'entangled!'
 Edited by GadgetGuy - June 10 2013 at 13:10
 Ken B - Live every day like it's your last.  Eventually, you'll get it right!
          This is just a "goose" of this topic.  My home theater
           | Posted: June 10 2013 at 13:19 | IP Logged |   |
 |  interface badly needs help.
 I'm using a URC MX-980 Universal Control, which is
 extremely capable, thus it controls some things directly
 and more complex items I control from a PH Trigger off
 the MX-980 key press.  The problem is that for some
 reason about 5% of the time PH misses the Trigger and
 only the remote initiated actions occur. Clearly this
 results in strange action sequences, and is not good.
 I'm thinking that if I create a virtual THEATER device
 and put it in the Responders area of the Remote Links,
 then that virtual device will perhaps get reliably set
 and thus serve as a more accurate trigger than the PH
 Direct Trigger.  Just saying, you know?
 Anywho, my new Virtual Device never responds to linked
 real world events.  Am I totally misunderstanding the
 design of the Virtual Device approach?
 Edited by GadgetGuy - June 10 2013 at 13:20
