| Posted: November 04 2006 at 10:40 | IP Logged
The Calendar Picker starts at 1900!
In Insteon Controllers, the Max Failure text box does not retain new values (always zero).
| Posted: November 06 2006 at 12:23 | IP Logged
Give me some more info on the Calendar picker. It should open to the date that appears in the Timed Event. A new Timed Event should have the current date/time. I played around a little and couldnt get it to fail.
The Max Failure box sticking is fixed in the new phupg.exe on the download page. Download this, overwrite the old and rebuild your database. It should work properly after that.
Let me know,
| Posted: November 06 2006 at 13:10 | IP Logged
Ah! I was not in the Timed Events area! lol
I'll check out the other stuff tonight!
| Posted: November 06 2006 at 13:52 | IP Logged
You're right, my bad. I had forgotten that I had included the "Calendar Picker" in areas other than the Timed Events screen.
Anyways, Ive made the corrections and if the data contains valid date information, it will use it to seed the calendar picker. If the data does not contain any valid date or time info, then it will use the current date and time.
Thanks for catching this for me,
| Posted: November 06 2006 at 19:37 | IP Logged
Looks good!
Edited by TonyNo - November 06 2006 at 19:40
