MrGibbage Super User
| Posted: April 17 2010 at 09:01 | IP Logged
For you regex experts...
How can I get the text between two tags in PH?
For instance:
<tagname>My Text</tagname>
I want to write a function/formula that I can pass "tagname" and it should return "My Text". In PH terms, of
course "My Text" can be stored in a local variable.
| Posted: April 17 2010 at 10:04 | IP Logged
If I understand your question correctly, I use POSW and MID to accomplish getting text between two tags. (3,21) Points to the start of data, (3,26) is the start tag1, and (3,27) is the end tag2. Of course it’s a little messier than just searching between two tags with one command.
ph_setvar_a(3,26, posw( ph_getvar_s(3,21), ".NOW." ))
ph_setvar_a(3,27, posw(ph_getvar_s(3,21),"$$",ph_getvar_n(3,26)))
mid(ph_getvar_s(3,21), ph_getvar_n(3,26), ph_getvar_n(3,27) - ph_getvar_n(3,26) )
| Posted: April 17 2010 at 14:45 | IP Logged
Pete's method will indeed work but if you want to use the Regex way, this would be the formula to use. The below formula is assuming that the text to search is in [LOCAL1] and the tag to search for is in [LOCAL2]:
ph_regexsnap("<" + ph_getvar_s(1,2) + ">\(.+\)</" + ph_getvar_s(1,2) + ">",ph_getvar_s(1,1),1,0)
Below is the same function but with sample text plugged into where the LOCAL vars are:
ph_regexsnap("<tagname>\(.+\)</tagname>","<ta gname>My Text</tagname>",1,0)
| Posted: April 18 2010 at 16:17 | IP Logged
I went with Dave's method. Works perfectly. I knew there'd be a simple way.
syonker Senior Member
| Posted: August 03 2014 at 07:41 | IP Logged
Gang,
I am noticing some very unfamiliar escape codes around the
forum. Wondering if anyone had a reference table or
similar that lays out all of the escape codes and how they
are used?
Thanks in advance for any help.
-S
><(((º>`·.¸¸.·´¯`·.¸><(((º>¸.
| Posted: August 03 2014 at 08:26 | IP Logged
While I'm on this line of programming questions I wanted
to
ask:
Does "~255" (as used in the example below) mean "Skip
until
whatever is past here is reached"...?
ph_regexsnap('<td>Wind Gust</td>~255<span
class="nowrap"><b>\(.+\)</b> mph</span> ',"
[LOCAL1]",1,1)
-S
Edited by syonker - August 03 2014 at 08:27
| Posted: August 04 2014 at 07:06 | IP Logged
Yes. From the Help file...
The ~255 approach allows you to perform multiple searchs within your search pattern (even across multiple lines). Only the last search, of multiple, can be used for Returning "snapped" data. NOTE: the ~255 character is NOT a part of the regular expression syntax and is strictly a PH special creation to separate regex searches.
| Posted: August 06 2014 at 07:36 | IP Logged
Hi Tony,
Thanks for the clarity - for whatever reason my bleary-eyed paradigm prevented me from finding that clearly in the help. So the "~" is actually the escape character used to access a direct ASCII reference? In this case character 255? Hence a "~10~13" is equivalent to "Carriage Return/Line Feed" and "~0" would be (not that you'd ever use it) a null character?
-S
| Posted: August 08 2014 at 18:16 | IP Logged
S,
Just to followup on the above. The ~ character is a PowerBuilder (the language that PowerHome is written in) string escape character. If you wanted CR/LF, then you could simply use ~r~n. ~b is backspace, ~t is tab, and ~~ is just the tilde. If the ~ character precedes a number, then PB is expecting a 3 digit ANSI character value in decimal format. So ~10~13 would really be ~010~013. If you prefer hex, then you can use ~hXX where XX is two hex digits. You even have the option of octal which would be ~oXXX where XXX are 3 octal digits.
So the ~255 above (or ~hFF) is exactly that...an ANSI decimal 255 character.
