| Posted: January 01 2007 at 20:26 | IP Logged
I use a Insteon trigger to fire a macro that checks the local brighness level whenever there is ANY Insteon change. The change could happen via a remote command (touchscreen), or a local (manual) level change.
When changing the level maually, I have found that I must add a 0.8 sec wait when I use the "ph_getinsteonlevel" command in order for it to return the right brightness level.
If I do not add this wait, PH returns a value that is only part way to the brighness level that I manually changed the light to.
What I find odd is that I can see my trigger first fire the macro when I start the manual change, and then it fires again (as it should) when I stop the manual insteon change. So, my trigger and macro (to check and update the local level) runs twice. You would think the last run of the macro (the one that fired on the Stop Manual Change) would report back the proper Insteon level that the device was brightened to. It doesn't, UNLESS you add the 0.8 sec wait.
Is this a bug, or Insteon shortcoming, or a function of how PH queues up the macro run order?
In order to NOT slow my system down by this 0.8s sec wait when I press my touchscreens, I have set up another trigger that only fires on the Insteon incoming "Stop Manaul Change" message (for manual changes only). This trigger then calls a macro with the 0.8 sec wait. At least this way, my remote commans (and feedback) are not slowed down (only my manual ones are). Hope this makes sense.
| Posted: January 17 2007 at 22:48 | IP Logged
Steve,
I know exactly what you're talking about and it's kind of an Insteon shortcoming.
When you press and hold a switch, you get a start manual change command as you've found. When you let up on the switch, a Stop manual change command is sent but the new brightness level that is reached is not a part of that command. So what PowerHome does automatically for you is generate a status request command to retrieve the current brightness level (it does this not only for the switch that manually dimmed but also for every device that may be linked as a group). This is why you get the correct level only after the 0.8 second delay. It is taking PowerHome (and Insteon) a certain amount of time to request the current status and have that level reported back. It would have been nice if the stop manual change command reported new level but unfortunately it doesnt (there is room for it however in command 2 so I don't know why this wasnt implemented).
