          Yep, sure is...use the ph_htmlcolor function.  This function takes a PowerHome RGB color and converts it to a string in the form #XXXXXX.
           | Posted: December 02 2005 at 22:38 | IP Logged |   |
 A PowerHome RGB color is merely the following formula:
 Red + (256 * Green) + (65536 * Blue)
 where each of the colors is a value from 0 to 255.  Once you have an RGB value, you can use math to extract it like so:
 int(rgb / 65536)
 gives you the blue component.
 int((rgb - int(rgb / 65536) * 65536) / 256)
 gives you the green component.
 rgb - int( rgb / 65536) * 65536 - int((rgb - int(rgb / 65536) * 65536) / 256) * 256
 gives you the red component.
 That last one gets a little long and messy.  The above formulas are based solely upon standard math.  We can also get the values by using bitwise ANDing as demonstrated in the formulas below:
 ph_and(rgb,16711680) / 65536
 gives you the blue
 ph_and(rgb,65280) / 256
 gives you the green
 ph_and(rgb,255)
 gives you the red.
