        | lllxx Newbie
          Hi,
           | Posted: September 03 2005 at 06:26 | IP Logged |   |
 I just purchased my PH and I try to resolve a stupid problem.
 I need to repeat as RF some X10 command because some of my plugs do not receive commands from everywere.
 My only problem is that doing that I create trigger loop adn I do not have any idea to how resolve that (basically I receive a a1 on and I repeat the same on RF) only problem my transceiver put the a1 on back on the powerline and I get the command again.
 any idea?
 Luigi
          Luigi,
           | Posted: September 03 2005 at 10:50 | IP Logged |   |
 Should be simple enough to correct.  I'll need a little more info on your system however.
 It sounds as if you're using a CM17A to transmit RF (what controller number is it?) as well as a powerline based X-10 controller (such as the CM11A).  Also, if you could give me just a little more info about the trigger, it would help.
 Im going to go ahead and take a crack at it though.  It sounds as if you have a trigger on A1 ON incoming X-10 (powerline, not RF).  When this trigger fires, it repeats the A1 ON command using a CM17A.  The problem is a transceiver picks up the RF and puts the A1 ON back on the powerline only to fire the trigger again.
 If that is correct, I would probably look at setting my A1 ON incoming trigger to call a macro.  The first line of this macro would check to see if this macro is already in the macro waiting queue.  If not, send the command and then wait for a second or two.  So the first time the A1 On triggers the macro, we check to see if it is waiting and it's not.  So we send the RF command and then the macro starts waiting.  This of course winds back up on the powerline and fires the trigger.  The macro is called, the first line checks to see if it is waiting (it is), so we just exit the macro and break the loop.
 Let me know how this goes or if Im on the right track.
        | TonyNo Moderator Group
          Dave responded as I was doing the same! His was better!
           | Posted: September 03 2005 at 11:00 | IP Logged |   |
 Edited by TonyNo
        | lllxx Newbie
          HI,
           | Posted: September 03 2005 at 18:46 | IP Logged |   |
 Thanks for the reply, so some info I use for the RF a CM17A and for PL a Powerlinc USB.
 The A1 On is already a Macro, and is set as Immediate and not queued.
 My only question is how can I exit from a macro? I don't find any command that stop a macro execution so where I need to see?
 Luigi
          One way to exit a macro is to do a JUMP 999.
           | Posted: September 03 2005 at 19:00 | IP Logged |   |
        | lllxx Newbie
          Hi,
           | Posted: September 03 2005 at 19:04 | IP Logged |   |
 I found the way using the Jump instruction in the Macro and I used this formula as line 10 (first)
 ph_ismacrowaiting("1WLON)*100
 I suppose that if the macro is waiting is going to return the number of macros, so multiplied by 100 is going the exit from the macro.
 I added also a delay of 1500 millisecond.
 With this costruction is working, is the correct way to do that or there is a better or more elegant way to do that?
 Luigi
        | lllxx Newbie
          Hi,
           | Posted: September 03 2005 at 20:16 | IP Logged |   |
 I still having the same problem the loop is endless.
 I modified the macro in this.
 I tried also to modify the macro in this :
 10 JUMP [ if(ph_ismacrowaitin("1WLOFF")>0, 3, 1)
 20 X10 2 A 1
 30 X10 2 A OFF
 40 Formula immediate ph_killmacrowait("1WLOFF")
 50 Delay    1500
 Any Idea?
 Luigi
          Change Delay 1500 to Wait 2 (Wait is in seconds). A Delay just does nothing for that time.
           | Posted: September 03 2005 at 22:18 | IP Logged |   |
        | lllxx Newbie
           | Posted: September 03 2005 at 23:18 | IP Logged |   |
 now work fine.
 Luigi
          Luigi,
           | Posted: September 05 2005 at 16:58 | IP Logged |   |
 I see Tony has filled in in my absence
 Anyways, the difference between the Delay and Wait commands is that a Delay pauses ALL execution until the Delay is finished.  Really only useful for very small timings such as to keep Infrared commands from being spaced to close together.  The Wait command however, takes a snapshot of the macro's variables, terminates the macro, and allows other events to be processed.  After the Wait period is over, the macro is reloaded with it's saved variables and execution continues where it left off.
 As far as executing a macro, a macro terminates when it the last statement is reached, so as Tony indicated, by jumping to a statement beyond the last (999 in his example), the macro will terminate.  You can also use the "End Macro" macro command.
 Concerning your macro, I would structure it as follows:
 10 Jump if(ph_ismacrowaiting("1WLOFF") > 0,999,1)
 20 X-10 2 A 1
 30 X-10 2 A OFF
 40 Wait 2
 The first line checks if the macro is already waiting.  With the first occurence of A1 OFF, it wont be so we'll jump to the next line.  Here we'll send the A1 and A OFF X-10 commands.  We'll then Wait for 2 seconds.  Sometime within this 2 second wait, we should receive the repeat A1 Off command from the powerline command we just issued.  The trigger will call the macro again and this time we'll be waiting.  So we'll just jump 999 and exit the macro thereby breaking the loop.
 PS, Thanks Tony!!
