        | phil13 Groupie
          Hi,
           | Posted: May 25 2005 at 03:24 | IP Logged |   |
 is there a way from a command line or an other application to send datas to powerhome ?
 Something like that : EXEC "powerhome.exe %DATA1"
 And how can i get it in powerhome ?
 philippe
        | TonyNo Moderator Group
          There are a few ways to get data into PH...
           | Posted: May 25 2005 at 08:07 | IP Logged |   |
 In my latest exersize, I used a batch file to ping some local machines and redirected the output to a text file. I then read the text file into PH and pull out info from it.
 If your app supports Windows Messaging, PH can send and receive data using this.
 The PHCommand util in the download section could also be used, depending.
 Anyone else have other ideas?
        | phil13 Groupie
          tony,
           | Posted: May 25 2005 at 09:28 | IP Logged |   |
 i've though about text file but what's append if powerhome want to read it and the other application want to write in it in the same time ?
 Does windows manage this problem ?
 Otherwise, the Phcommand utility seems to be a very good and powerfull idea. I've tried but i've a problem.
 The utility documentation say need to have PBVM80.DLl, LIBJCC.DLL and PH32.DLL installed but on my computer i can't find pbvm80.dll but i've a pbvm90.dll ...
 Does someone heve pbvm80.dll ?
          Don't they come with phcommand? I have them in my phcommand folder. Maybe I copied them there from somewhere else?
           | Posted: May 25 2005 at 12:54 | IP Logged |   |
 I would send it to you, but I don't know if there are licensing issues. Dave should be able to assist here.
        | phil13 Groupie
           | Posted: May 25 2005 at 13:25 | IP Logged |   |
 it don't come with phcommand.zip.
 After a little search it seems that :
 - pbvm90.dll is for PowerBuilder 9.0
 - pbvm80.dll is for PowerBuilder 8.0
          Phil,
           | Posted: June 01 2005 at 11:47 | IP Logged |   |
 The phcommand.zip in the download section is a little outdated.  I would post the pbvm80.dll (and other PowerBuilder 8.0 runtime files) except that I don't have it loaded on my new development machine (old notebook crashed).
 I will rework this utility to use the latest runtimes and post them when I have it done.
          Check out the PowerHome Download page.  At the bottom Ive added two new utilities for command line control.
           | Posted: June 10 2005 at 18:02 | IP Logged |   |
 The first is command line control using the PowerHome Windows Messaging interface.  This program will allow you to execute a formula from the command line of the local PowerHome machine.  Includes complete VB source code.
 The second is a command line control utilizing the PowerHome Socket Server interface.  Using the program will allow you to control PowerHome from the command line of the local machine AS WELL as any remote networked machine.  Requires the socket server interface be enabled within PowerHome.  Again, with complete VB source code.
 One of these utilities should do the trick for you.
          Cool! Are these different from phcommand?
           | Posted: June 10 2005 at 19:06 | IP Logged |   |
          I just d/l'ed phsscmd_setup.exe and got this error...
           | Posted: June 10 2005 at 19:17 | IP Logged |   |
 Error 1324.The path ***IS_STRING_NOT_DEFINED***
 contains an invalid character.
        | krommetje Super User
          I've got the same problem here!
           | Posted: June 12 2005 at 10:59 | IP Logged |   |
 Peter
          It was a bad build from InstallShield.  I just rebuilt the install and uploaded it.  Give it a try and let me know if this one is ok or not.
           | Posted: June 12 2005 at 22:21 | IP Logged |   |
 Yep, a little different from the old PHCommand.  The PHCommand was written in PowerBuilder necessitating the PowerBuilder runtimes.  I believe it also used the webserver as the interface.  Both of the new files are written in VB with source code (for learning purposes) and use the newer Windows Message and Socket Server interfaces.
 Good luck,
        | phil13 Groupie
          Thanks dave.
           | Posted: June 13 2005 at 09:52 | IP Logged |   |
        | phil13 Groupie
           | Posted: June 13 2005 at 11:35 | IP Logged |   |
 i've tried to load VB projects and i had somes problems i think because i'm using Visual basic express 2005 beta 2.
 http://lab.msdn.microsoft.com/express/vbasic/default.aspx
 When i make the automatic update from vb6 to vb 2005 :
 - i can't open phsscmd because problems of winsock licence
 - i can open phwmcmd but i've upgrade issue in code :
 (sorry for french but my vb is in french ...)
 Friend Class PHWMCmd
 'UPGRADE_ISSUE: La déclaration d'un paramètre 'As Any' n'est pas prise en charge. Cliquez ici :  'ms-help://MS.VSExpressCC.v80/dv_commoner/local/redirect.htm ?keyword="FAE78A8D-8978-4FD4-8208-5B7324A8F795"'
 'UPGRADE_WARNING: Impossible de résoudre la propriété par défaut de l'objet cds. Cliquez ici :  'ms-help://MS.VSExpressCC.v80/dv_commoner/local/redirect.htm ?keyword="6A50421D-15FE-4896-8A1B-2EC21E9037B2"'
 iRet = SendMessage(hPwrHome, 74, 0, cds)
 End Class
          Philippe,
           | Posted: July 05 2005 at 11:20 | IP Logged |   |
 Im not familiar with VB 2005 Express so not sure what upgrade issues you may have.  However, the code is very simple so I'll just copy and paste it below.
 The code for phwmcmd is:
 Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
 Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByRef lParam As Any) As Long
 Private Type COPYDATASTRUCT
 dwData As Long
 cbData As Long
 lpData As String
 End Type
 Dim hPwrHome As Long
 Dim cds As COPYDATASTRUCT
 Private Sub Form_Load()
 Dim sData As String
 Dim iRet As Long
 sData = Command()
 hPwrHome = FindWindow(vbNullString, " PowerHome  ")
 If hPwrHome = 0 Then
 MsgBox ("PowerHome is not running")
 End If
 cds.dwData = 0
 cds.cbData = Len(sData)
 cds.lpData = sData
 End
 End Sub
 The code for phsscmd is:
 Private Declare Function GetPrivateProfileString Lib "kernel32.dll" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As String, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Integer, ByVal lpFileName As String) As Integer
 Dim sReturnData As String
 Dim bConnect As Boolean
 Sub form_load()
 Dim sRemoteHost As String
 Dim sRemotePort As String
 Dim sUserID As String
 Dim sPassword As String
 Dim sEncode As String
 Dim sAuthorize As String
 Dim sContentLength As String
 Dim sFormula As String
 Dim tStart As Date
 Dim tEnd As Date
 sFormula = Command()
 sRemoteHost = Space(256)
 sRemotePort = Space(256)
 sUserID = Space(256)
 sPassword = Space(256)
 sRemoteHost = Left(sRemoteHost, GetPrivateProfileString("settings", "remotehost", "127.0.0.1", sRemoteHost, Len(sRemoteHost), ".\phsscmd.ini"))
 sRemotePort = Left(sRemotePort, GetPrivateProfileString("settings", "remoteport", "8500", sRemotePort, Len(sRemotePort), ".\phsscmd.ini"))
 sUserID = Left(sUserID, GetPrivateProfileString("settings", "userid", "yourname", sUserID, Len(sUserID), ".\phsscmd.ini"))
 sPassword = Left(sPassword, GetPrivateProfileString("settings", "password", "yourpassword", sPassword, Len(sPassword), ".\phsscmd.ini"))
 Winsock1.RemoteHost = sRemoteHost
 Winsock1.RemotePort = CLng(sRemotePort)
 bConnect = False
 Winsock1.Connect
 tStart = Now
 Do
 tEnd = Now
 DoEvents
 Loop While bConnect = False And DateDiff("s", tStart, tEnd) < 10
 If bConnect = False Then
 Winsock1.Close
 End
 End If
 sAuthorize = "Authorization: Basic " + base64encode(sUserID + ":" + sPassword)
 sContentLength = "Content-Length: " + CStr(Len(sFormula))
 sReturnData = ""
 Winsock1.SendData ("FORMULA" + vbCrLf + sAuthorize + vbCrLf + sContentLength + vbCrLf + vbCrLf + sFormula)
 tStart = Now
 Do
 tEnd = Now
 DoEvents
 Loop While bConnect = True And DateDiff("s", tStart, tEnd) < 20
 If bConnect = True Then
 Winsock1.Close
 End
 End If
 Winsock1.Close
 End
 End Sub
 Sub winsock1_DataArrival(ByVal bytestotal As Long)
 Dim sTemp As String
 Winsock1.GetData (sTemp)
 sReturnData = sReturnData + sTemp
 End Sub
 Sub winsock1_Connect()
 bConnect = True
 End Sub
 Sub winsock1_Close()
 bConnect = False
 End Sub
 Function base64encode(sData As String)
 Const base64 =  "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456 789+/"
 Dim lBlock As Long
 Dim iCount As Integer
 Dim iLen As Integer
 Dim sTail As String
 iLen = Len(sData)
 iCount = 1
 Do While iCount <= iLen
 lBlock = Asc(Mid(sData, iCount, 1)) * 65536
 iCount = iCount + 1
 If iCount <= iLen Then
 lBlock = lBlock + Asc(Mid(sData, iCount, 1)) * 256
 iCount = iCount + 1
 iCount = iCount + 1
 sTail = ""
 Else
 sTail = "="
 End If
 Else
 sTail = "=="
 End If
 sEncode = sEncode + Mid(base64, (lBlock And &HFC0000) / 262144 + 1, 1)
 sEncode = sEncode + Mid(base64, (lBlock And &H3F000) / 4096 + 1, 1)
 If sTail <> "==" Then
 sEncode = sEncode + Mid(base64, (lBlock And &HFC0) / 64 + 1, 1)
 If sTail <> "=" Then sEncode = sEncode + Mid(base64, (lBlock And &H3F) + 1, 1)
 End If
 sEncode = sEncode + sTail
 Loop
 base64encode = sEncode
 End Function
 As far as the Winsock Control licensing issue....Im not sure if this control is included with VB Express so that may be the issue.  You can however see the events that Ive coded for the Winsock Control and you may be able to create the project from scratch if importing is a problem.
