| fasttimes Groupie
          I'm trying to create a graphic represenation on the control center of my KeypadLinc with 8 buttons.
           | Posted: March 28 2006 at 03:17 | IP Logged |   |
 How can I programmatically change the state from "on" to "off" and vice-versa?
 I ask b/c I have a trigger which catches the on button, and performs some light changes, then after 5 minutes, does some more changes then turns the KPL button off.  I want to have the control panel match the actual KPL.
 Any ideas?
        | TonyNo Moderator Group
          Take a look at ph_setccbtn.
           | Posted: March 28 2006 at 07:20 | IP Logged |   |
 This formula updates a button (#2 on the Devices tab) to reflect the state of a device (C3) by changing its color...
| Code:
       | ph_setccbtn ( "DEVICES", 2, " ", -1, -1, -1, -1, if( ph_getx10stat( "C3") = 1, rgb ( 255, 255, 255 ), rgb ( 0, 0, 0 ) ), if( ph_getx10stat( "C3") = 1, rgb ( 200, 0, 0 ), rgb ( 0, 200, 0 ) ), -1 ) |  |  |
 This needs to be done in a macro that is called out in Setup, Control Center, Run Macro on Open.
 Edited by TonyNo - March 28 2006 at 07:34
