        | nadler Super User
          Okay, all you macro/function buffs - I want to report the status of a number of insteon devices so that I can announce them.  For example, at 11 pm I might want TTS to say "The Garage is Open" or "The living room light is still on" after first checking the status of the particular Insteon device.
           | Posted: May 07 2006 at 15:53 | IP Logged |   |
 |  I've tried:
 Set System   [LOCAL1]   ph_insteon ("COMPUTER LIGHT1", istatus,0)
 TTS     [LOCAL1]
 This reports "ZERO" which means that the function was executed correctly.  How do I get the function to return the actual status of the device (i.e. - On or Off or even the number 17,18, 20 etc)?
          Nick,
           | Posted: May 07 2006 at 17:21 | IP Logged |   |
 The correct command would be ph_getinsteonstat and ph_getinsteonlevel.  I would just use a single TTS line with the TTS field being:
| Code:
       | "The Garage Door status is " + case(ph_getinsteonstat("GARAGEDOOR") when 0 then "unknown" when 1 then "closed" when 2 then "open") |  |  |
 After rereading your post though, it looks like you want to check for a particular status and then announce a certain condition.  The code would then look something like:
| Code:
       | 10 Jump if(ph_getinsteonstat("GARAGEDOOR") = 2,1,999)
 20 TTS "The garage door is still open"
 Let me know if this answers your question or not.
        | nadler Super User
          Perfect.  That's exactly what I was looking for.  I'll add it to my Power-Home Tips and Tricks.
           | Posted: May 07 2006 at 18:43 | IP Logged |   |
 Just curious.  Under what circumstances would you use "istatus" in the ph_insteon(device,istatus,0) function?
 Thanks.
 Noel
          Noel,
           | Posted: May 08 2006 at 17:19 | IP Logged |   |
 (Sorry about the Nick...hard to keep track sometimes
  ).  Glad that helps.  As far as "istatus" is concerned, it's just a way to force a check of the status.  It's not instantaneous however.  Youre basically telling the Insteon controller to send a status command to a device.  The controller sends the command and when the device gets a chance, it will respond with it's current status.  PowerHome will receive this incoming response to status and will update the Device Status screen accordingly.  Usually it's pretty quick, but if a lot of traffic is currently taking place (such as a link retrieval or create) then there may be a several second second delay.
        | nadler Super User
           | Posted: May 09 2006 at 10:05 | IP Logged |   |
 |  Don't worry about it.  I've been called a lot of things.  Nick isn't so bad.
 Thanks for the info on istatus.  Another entry for my Tips and Tricks.
 I'm starting another thread with a couple of other macro questions.
