        | ginigma Senior Member
          I'm trying to put the functions of a ControLinc (5 button) on a CC tab.  I understand there is no direct call so I would have to use a formula.  I was thinking of ph_insteonrawgroup, but it looks like that only controls groups on a PLC.  Is that correct?
           | Posted: January 10 2007 at 22:25 | IP Logged |   |
        | cmhardwick Senior Member
          You can only control PLC groups
           | Posted: January 11 2007 at 08:48 | IP Logged |   |
 |  If you want to control the same lights as the controlinc does, you'll have a to create a duplicate group in the PLC.
 HTH
 Cicero, Enjoying automation!
          Ginigma,
           | Posted: January 17 2007 at 22:25 | IP Logged |   |
 Cicero has you covered.  Ive requested to SmartLabs that they make an extension to the Insteon protocol so that the PLC can "trigger" another devices stored groups but I don't think we'll be seeing it anytime soon.  Since an Insteon device cannot tell another Insteon device to send it's "group" command, you'll have to duplicate that group as a PLC group and call that instead.
