        | skoondy Newbie
          Hi, total newbie here.
           | Posted: January 08 2007 at 19:51 | IP Logged |   |
 I'm wondering if this is even possible, so hopefully someone can help me out in *beginner's* terms!
 I would like to set up a night-time light system for my daughter, where if she turns on her bedroom light (Insteon SL) between 10pm and 5am, then her light will come on at 25%, the hallway light at 25% and the bathroom light at 50%. After 5 minutes they will all turn off.
 When she turns her light on outside of those hours, only her own light comes on at 100%.
 I think I understand the basics of using macros, formulas and timed events in PH. And I've grouped the switches mentioned above, with the USB PLC as the controller.
 Any help is appreciated!
 Chris
        | TonyNo Moderator Group
          Welcome to PowerHome!
           | Posted: January 08 2007 at 20:28 | IP Logged |   |
 I believe what you need to do is first set the SwitchLinc On-Level to minimum brightness, then create a trigger that checks the time and does the appropriate thing.
 The trigger (of type "Formula") would look something like this...
 if( hour(now()) > 22 or hour(now()) < 5, ph_macro("DAUGHTER LIGHT"), bright 100%)
 The macro ("DAUGHTER LIGHT") would send the group on, do a wait for 5 minutes, then send the group off.
 Let me know if you need more specifics!
        | skoondy Newbie
          Thank-you so much for your quick reply!
           | Posted: January 08 2007 at 23:11 | IP Logged |   |
 Just rethinking this...it might be better to program this the opposite way if possible (ie: where ON at 100% is the norm, and the macro runs the dimmed group during a specified time period). What formula would you suggest for this?
 Also, when writing the macro ("DAUGHTER LIGHT"), is it possible to specify the brightness levels for each individual switch?
 Thanks again!
 Chris
          Since it is likely that the SwitchLinc controls a local load (the light), you'll need to set the On-Level to that low value. The switch turns the light on, then sends the signal that it was turned on. If you do what you say, the light will come on at 100%, then dim to 25% during the selected time.
           | Posted: January 09 2007 at 07:29 | IP Logged |   |
 You can set the individual dim levels in the group (links).
        | skoondy Newbie
          You are correct, the SL controls the local load...thank-you so much for your help. I will try what you've suggested!
           | Posted: January 09 2007 at 09:04 | IP Logged |   |
        | skoondy Newbie
          Hi,
           | Posted: January 09 2007 at 16:35 | IP Logged |   |
 I created the macro ("SYD NIGHT LIGHTS") as you suggested, using a 300 second wait between the on and off commands. I then created a trigger pasting the code you sent me into the Action column (changing the macro reference)...and PH is not accepting this (ie: giving me an error).
 When I run the formula checker, it gives me a response of ".!"
 I also used:
 ID = SYD1
 Description = SYD NIGHT LIGHTS
 Action Type = Raw Formula
 Action Style = Queued
 Status = Active
 Trigger Type = Insteon Device Chg
 Trigger ID = ID# of the SL in my daughter's room
 Am I doing something wrong here?
 Chris
          Heh. You need to code the proper version of "bright 100%" (using ph_insteon()).
           | Posted: January 09 2007 at 16:57 | IP Logged |   |
 I'll look at this tonight for you.
          Here is the proper version...
           | Posted: January 09 2007 at 19:49 | IP Logged |   |
 if( hour(now()) > 22 or hour(now()) < 5, ph_macro("SYD NIGHT LIGHTS"), ph_insteon( "DEVICE ID", ion, 255 ) )
        | skoondy Newbie
          Hi,
           | Posted: January 10 2007 at 13:07 | IP Logged |   |
 Still having issues here! (Told you I am very new at this
 I created a trigger using the following variables:
 ID = SYDLIGHT
 Action = if (hour (now()) > 22 or hour(now()) < 5, ph_macro("SYD NIGHT LIGHTS"), ph_insteon( "15", ion, 255) )
 Action Style = Immediate
 Status = Active
 Trigger ID = 15
 Trigger ID Number = 1
 Trigger Value = On
 Boolean = 1 (the default value)
 When I verify the formula outside of 10pm and 5am it gives me a result of "0" and turns on the light at 100%. However, when I save & reinitialize PH and manually turn the SL on in her room, it only brightens to the preset level - not to 100% as the formula would suggest.
 For some reason the trigger is not being recognized??
 Thanks again!
 Chris
          Is the switch press shown in the log?
           | Posted: January 10 2007 at 13:26 | IP Logged |   |
 Try these too...
 1. The action style should be Queued.
 2. Try adding a second Trigger Type of Insteon Group In, Trigger ID of the SL, Trigger ID Number of "(Any)", and a Trigger Value of On.
 3. Try adding a small delay before calling the macro...
 ph_delay(500)+ph_macro("SYD NIGHT LIGHTS")
 Number 3 is for the heck of it. It seems to fix missing-trigger issues that I have seen before.
        | skoondy Newbie
          Hi,
           | Posted: January 11 2007 at 15:46 | IP Logged |   |
 No the SL press is not showing up in the log.
 Chris
          Maybe you did not link the SL to the PLC?
           | Posted: January 11 2007 at 20:34 | IP Logged |   |
 If so, I would guess that you are having communications problems.
 If not, the SL needs to be linked so that it can see the switch being operated.
          Skoondy,
           | Posted: January 17 2007 at 22:22 | IP Logged |   |
 Just wondering if you ever got this worked out or not.
