        | jpcurcio Senior Member
          Nadler:
           | Posted: April 26 2007 at 03:13 | IP Logged |   |
 I have some questions regarding the VBscripting you've done for iTunes.  I'm trying to write a couple scripts myself, but some don't seem to work, while others are just fine.  Can you perhaps give me some guidance?
 Thanks...
 -JPC
        | nadler Super User
          Unfortunately, I kinda just copied what Dave had done and modified it a little using trial and error.  I really don't know VBscripting.  If you search the threads and ask Dave some questions, he should be able to help.
           | Posted: April 26 2007 at 07:05 | IP Logged |   |
           | Posted: April 26 2007 at 22:44 | IP Logged |   |
| nadler wrote:
       | Unfortunately, I kinda just copied what Dave had done and modified it a little using trial and error.  I really don't know VBscripting.  If you search the threads and ask Dave some questions, he should be able to help. |  |  |
 Actually, my main questions were regarding the various commands available.  I downloaded the iTunes SDK, and can figure out some of the commands (I use this mostly for documentation), but I find that they don't necessarily work for me.
 One of the things I'd like to do is toggle the shuffle and repeat modes.  I find the commands, but they don't seem to work.  I also had some issues with your script to select the playlists, so I'm not sure if it's me or not.
 -JPC
        | nadler Super User
          This following works for me to mute itunes. Hope this helps.
           | Posted: April 27 2007 at 17:40 | IP Logged |   |
 Here is the PH formula I use to call the script:
 ph_runscript_1("C:\Program Files\iTunes\Scripts\Mute.vbs","vbscript",0,0,"main","")
 Here is the vbscript I use which toggles muting in itunes.
 sub main(arg)
 Dim iTunes
 Dim ArgStr
 Dim Msg
 ' Create app object
 Set iTunes = CreateObject("iTunes.Application")
 ' Get the argument
 argstr = lcase(trim(arg))
 ' Now interpret the argument and act accordingly
 Select Case ArgStr
 Case "on"
 iTunes.Mute  = True
 Case "off"
 iTunes.Mute  = False
 Case ""
 ' Toggle
 iTunes.Mute  = Not (iTunes.Mute)
 Case Else
 Msg = "Please specify 'Mute on' or 'Mute off' to set the mute state, or 'Mute'"
 Msg = Msg + " (without an argument) to toggle the mute state."
 Echo Msg
 End Select
 ' Done; release object
 set iTunes = nothing
 ' msgbox "done"
 rem End of script.
 end sub
