Subject Topic: Windows Server 2008 R2 Post ReplyPost New Topic
Ktulu
Posted: July 11 2010 at 12:29 | IP Logged Quote Ktulu
Anyone have any success getting PowerHome to run on Windows Server 2008 R2? More specifically the Smarthome Device Manager? I can get PowerHome to run but sdm3.exe fails completely and without explanation.
Jeff
"Assiduus usus uni rei deditus et ingenium et artem saepe vincit" - Cicero
Back to Top View Ktulu's Profile Search for other posts by Ktulu
sjvonstein
Posted: July 11 2010 at 12:47 | IP Logged Quote sjvonstein
UAC may need to be turned off. Furthermore, be sure it is running as administrator. You may need to set a compatibility option to get it to run properly.
Back to Top View sjvonstein's Profile Search for other posts by sjvonstein
Ktulu
Posted: July 14 2010 at 18:35 | IP Logged Quote Ktulu
No joy. Tried both of those before posting and again after you suggested them. I'm starting to think that replacing my 2003 server might not be in the cards right now.
Jeff
krommetje
Posted: July 15 2010 at 02:03 | IP Logged Quote krommetje
I had the same Item some months ago when I got a 2008 server for testing purposes. I had 3 tests:
-powerhome has to run stable with Mapi (min. 1week)
-System processes may not cause PH to run unstable as a service.
-IIS with perl, ASP (.net) and PHP have to be installed and running on a multi-site server (+10 domains).
I was able to run PH next to IIS on seperate IP's but then my temperatures could not be read |(host headers messing up)
2008 has a system which backs up certain files daily and it did mess up PH's stability.
Mapi did not work (on this machine)
So I moved PH back to my Proliant Server on 2k3 server OS where it has been running continueasly for 4 months now.
Moving to 2008 is not an option IMHO.....
Peter
Ktulu
Posted: July 28 2010 at 15:28 | IP Logged Quote Ktulu
Peter
The concept of of not being able to run the latest server software on my new hardware is very depressing.
Oh well... I'm over it.
Where did I put my Windows Server 2003 R2 64bit disc?
Jeff
Ktulu
Posted: July 28 2010 at 15:29 | IP Logged Quote Ktulu
...on second thought. I'm going to see if I can get Powerhome doing what I need in a VM first.
Jeff
Ktulu
Posted: January 03 2011 at 17:28 | IP Logged Quote Ktulu
I had some time off around the holidays. In between bouts of massive non-productiveness, unless you consider leveling up in COD:Black Ops productive, I got PowerHome working and stable on Windows Server 2008 R2... kinda.
I cheated.
I have it running on a Oracle VirtualBox VM running Server 2003. So, actually it is running on a Server 2008 box, but technically, it's not. As always, what took hours to achieve took months to start.
BTW: I upgraded from a PLC to a USB Dual-Band PLM at the same time. Moving to a PLM is one of the best things I've done for my home automation system.
Jeff
moniputer
Posted: January 03 2011 at 20:58 | IP Logged Quote moniputer
I have been running PH for several months on a Windows Home Server "Vail" system which is based on Windows Server 2008 R2.
I use a serial PLM and do not use Mapi. Everything has been very stable so far.
Back to Top View moniputer's Profile Search for other posts by moniputer
yalk
Posted: January 24 2011 at 23:52 | IP Logged Quote yalk
A friend of mine was able to run PowerHome on windows server 2008 R2. He had done that about two months ago without any problem. But I am not 100% sure regarding Smarthome Device manager. Anyway, I have decided to forward the link to him. I think he will be able to help us in this regard.
hello
Back to Top View yalk's Profile Search for other posts by yalk
sifu128
Posted: February 08 2011 at 08:34 | IP Logged Quote sifu128
Hey guys, are there any instructions on how to get this to work with Win 2008 R2?
Dave
Back to Top View sifu128's Profile Search for other posts by sifu128
Ktulu
Posted: February 09 2011 at 08:44 | IP Logged Quote Ktulu
In retrospect, I think my initial problem with 2008 R2 was the SDM. If you're using a PLM, there might not be a problem at all.
However, I'm sticking with a virtualized server as it's much more flexible.
Jeff
sifu128
Posted: February 09 2011 at 09:05 | IP Logged Quote sifu128
I think that will be my problem as I am using the older 2414u SDM. Thanks for the info :)
